Posted: Fri Mar 22, 2013 6:44 am |
Posted: Fri Mar 22, 2013 7:00 am |
There different sizes
Posted: Fri Mar 22, 2013 9:35 am |
One is the tensioner which is needed. One is the roller which isn't needed if you bin the air conditioning! Both pulleys are different to each other so can't be swapped.
Posted: Fri Mar 22, 2013 9:41 am |
if u want the part number for these runners,send me your VIN,and it's better to get the original ones
Posted: Tue Mar 26, 2013 1:55 pm |
All sorted now no noise no more funny looks
Posted: Sun Mar 31, 2013 4:09 pm |
good to know,what did you do?
Posted: Sun Mar 31, 2013 5:25 pm |
Change the belt and roller no noise now thank god
Posted: Mon Apr 01, 2013 1:08 pm |
Zack wrote: |
Change the belt and roller no noise now thank god |
