![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › developed a drivers rocking chair ? |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Sat Mar 09, 2013 2:00 pm |
as the title says in my gti the drivers seat as started to rock slightly when accelerating or braking, and the seat as a slight rocking motion when sliding it backwards and forwards ?
is it a simple case of remove seat and tighten everything up or are my runners on there last legs lol no pun intended there lol ![Shocked Shocked](images/smiles/icon_eek.gif)
| | ![](images/spacer.gif) |
Posted: Sat Mar 09, 2013 2:39 pm |
It's the runners...or it could be the mechanism that changes the height.
Posted: Sat Mar 09, 2013 4:34 pm |
ahh nuts
| ![](themes/base/images/forums/otr.gif) |
