Forums › The Car › 206 Problems › Star Torque bit size on Rear Hub Plate |
Posted: Sat Mar 09, 2013 12:49 pm |
Anyone know what size Torque Bit I need to undo the x4 Star Torque bolts that hold the Rear Hub plate the the Axle Lower Arm?
Posted: Sat Mar 09, 2013 1:31 pm |
Nope but I imagine it's one that every torx set has.
Posted: Sat Mar 09, 2013 1:44 pm |
Nothing to do with the size of Torx Bit...
I am removing my rear axle at the moment ready for the new one to arrive.
I have managed to get one of the rear hubs off my car but I can not for the life of me get the the other side off!
I have even snapped a hub puller trying!
I have loosened the hand brake cable right off.
hit it with a hammer, but it just won't budge!
Any tips anyone?
