Online Now [642]:
Visitors: 641
Today: 259119
Total: 150087679
Forums › The Car › 206 Problems › clutch cable replacement
ct-xsi
PostPosted: Mon Mar 11, 2013 6:56 am Up
I think the auto adjuster is on its way out on the missis car. It very occasionally wont allow you to select a gear or knock it out of gear and there is a click from the clutch pedal when u try to clutch down when it does this.
I have fitted several to 106's and they were a pain in the balls. What are they like on a 1400 206?
Does it just have 2 nuts holding it threw the bulkhead and then onto the pedal? I cant really see how it fastens onto the pedal but assume it just hooks over it? Isit best to fit it to the pedal end first then onto the box?
thanks
20Drift
PostPosted: Mon Mar 11, 2013 10:39 am Up
This is the clutch pedal/cable assembly from Peugeot Service Box - hopefully it should help you a bit!
