Latest: lio94
Overall: 17181
Online Now [189]:
Visitors: 188
Today: 51454
Total: 141490446
Forums › The Car › 206 Problems › Central Locking
Central Locking
craig12321
PostPosted: Thu Feb 07, 2013 6:47 am Up
Hi Guys.
Im having an issue with my central locking. I have a Peugeot 206 LX.
All was working fine until yesterday evening. I simply tried to lock the door but the pins return up, usually they do this if something is jamming the door open. Checked all the doors but nothing strange stuck out.
The way i have managed to the lock the car is putting the key inside the door and holding it in the locked position this keeps the pin down i can then use the key to lock the passanger door.
Anyone have any advice to fix this or any tips?
New Driver, Bought a 206 LX in December, relaced passenger mirror, replace milage counter, replaced radiator. Car will finally be taxed this saturdat (25/02/12)
cully
PostPosted: Thu Feb 07, 2013 8:06 am Up
one of your doors is saying it is open
try reclosing all the doors!
the easyest way to diagnose this would be through plugging into a diagnotic machine
has anyone local to you got Peugeot planet diag system?
this will tell you which door is at fault
second option
which i have used for the rear doors only
is to unplug the door lock inside the door,
then try to lock it with the RCL fob
if it locks the other 3 without bouncing the locks that door switch is faulty in this door
quick tip
***rears only***
once finding the faulty lock cut wire number 1 in the plug and insulat the ends
plug the unit back in now the door should lock with the RCL fob
the bsi will think the door is closed all the time Wink
i only say this for the rears only as i have not looked at the wiring pinouts for the fronts
as i found my fault before getting to them
SAB206
PostPosted: Thu Feb 07, 2013 2:11 pm Up
Sounds like you need a new door locking solenoid/actuator on one of the doors.
www.sab-graphics.com
I AM SYDLEXIC!
craig12321
PostPosted: Fri Feb 08, 2013 8:09 pm Up
Thanks guys really appreciate the help.
In the mean time is there a way i can lock the boot as at the moment its the only thing i cant seem to lock Neutral
devilred206
PostPosted: Mon Mar 04, 2013 8:28 am Up
i got a similar problem i use the key to lock the doors and they bounce back up and doesnt lock only way i can lock it is by locking the drivers door manually and then go to the passengers side to unlock only thing is, is that the boot does not lock. and it unlocks when i push the button on the key fob soo where do i stand HELP !!!!!!
ryanovsalford
PostPosted: Mon Mar 04, 2013 10:07 am Up
there is a way to lock the boot manually by going threw the back seats sure someone on here could shed some light on locking the boot
seems like a very common problem with 206's bouncng locks i just changed all the solinoids in mine to sort it only because got a good deal on ebay
millow_99
PostPosted: Thu Mar 07, 2013 12:58 am Up
For the boot, an easy way to test if its working or not is to listen if you hear it bounce. It if does, it might mean that the system that retains it to the boot might have lost its holding screw. Mine did that and it was a pita cause I needed to go through the back seats to get to unlock it manually.
Pug Lover!
devilred206
PostPosted: Mon Mar 11, 2013 8:30 am Up
thanks for the help i have noticed one thing.. on the bottom catch there's a wire coming of and there's like a release switch there thats floating about is this what you mean ?? it clips in to place but stil does nothing
