Online Now [286]:
Visitors: 285
Today: 81747
Total: 142987449
Forums › The Car › 206 Problems › clutch cable replacement
ct-xsi
PostPosted: Mon Mar 11, 2013 6:56 am Up
I think the auto adjuster is on its way out on the missis car. It very occasionally wont allow you to select a gear or knock it out of gear and there is a click from the clutch pedal when u try to clutch down when it does this.
I have fitted several to 106's and they were a pain in the balls. What are they like on a 1400 206?
Does it just have 2 nuts holding it threw the bulkhead and then onto the pedal? I cant really see how it fastens onto the pedal but assume it just hooks over it? Isit best to fit it to the pedal end first then onto the box?
thanks
pug206lx
PostPosted: Mon Mar 11, 2013 4:37 pm Up
Ive done a few, inside there's a plastic hook that hooks over the end of the pedal, but there's a stupid annoying clip on the pedal that makes it difficult for you. The adjuster is indeed held in by 2 nuts on the outside of the bulkhead. the cable then just runs behind the engine, under the battery and to the gearbox arm.
