Latest: heikkisj
Overall: 17126
Online Now [63]:
Visitors: 62
Today: 7224
Total: 100379983
Forums › The Car › 206 Talk › 206 gti alternator
206 gti alternator
Zack
PostPosted: Tue Mar 05, 2013 2:53 am Up
Has any one changed the alternator belt on 206 gti.
Im changing my power steering pump and the belt looks tight any advise?
cheers
PostPosted: Tue Mar 05, 2013 6:46 am Up
16mm spanner on the tensioner. Easy to change from underneath.
Zack
PostPosted: Tue Mar 05, 2013 6:52 am Up
Thanks for your help again.
Smile
PostPosted: Tue Mar 05, 2013 6:53 am Up
Have a look at my project thread to see what it looks like as I fitted a new one.
Zack
PostPosted: Tue Mar 05, 2013 1:27 pm Up
you got link for this?
Zack
PostPosted: Sun Mar 10, 2013 11:05 am Up
Is the belt auto tensioner?
Cheers
Tolkienfan001
PostPosted: Sun Mar 10, 2013 11:24 am Up
Trade Rating: +13
Cheers
Yes use a spanner on the bolt on the auto tensioner to loosen the tension on the belt to take it off. Be careful to slowly release the tensioner as it will spring back. To change the belt is a ten minute job max.
2005 1.4 16v Sport
Check out my 206 here!
Zack
PostPosted: Sun Mar 10, 2013 11:53 am Up
Thank you Smile
