Forums › Tuning, Modification & Legal › Project Cars › Project sleeper |
Posted: Thu Jan 20, 2011 2:50 am |
I tried that but the thin housing just didn't give me confidence that the sensor would stay in place.
Posted: Thu Jan 20, 2011 12:18 pm |
I know what you mean, but the sensor i've got for my dash doesn't need lots of thread, i have pics somewhere.
| ICE goes in drinks. NOT in cars. | |
Posted: Thu Apr 14, 2011 8:01 am |
Meticulous as ever but will be perfection once completed!
Can't believe that Ecosse has messed you around so much.
| Please feel free to send any suggestions or general feedback to feedback206@email.com | |
Posted: Thu Apr 14, 2011 9:02 am |
Any more news on the project?
Are you going to take her to any shows, or keep her locked up like usual?
| Team Impossible Possible
Posted: Thu Apr 14, 2011 11:21 am |
Well these turned up yesterday. Only took eight weeks....Will order a new coolant reservoir and heater hose next week and put it all back together.
Might buy a proper Jenvey throttle linkage soon too because the throttle bodies reach their stop before the pedal does so it's possible to put a lot of pressure on the throttle splindles which isn't desirable and can twist them.
Next year or over the winter (maybe this summer - depending on lead time on custom radiators) I'll buy the shorter radiator, integrated fan and longer trumpets etc. I'll be getting the standard fan wired to the Omex this summer though to maintain reliability.
Posted: Thu Apr 14, 2011 12:03 pm |
Good move Ed.... the ECU control on the fan is important... I have mine in line and its set wrong by a couple of degrees I think.... fan comes in as soon as I am stationary and doesnt really go off even when moving... need to plug the laptop in and sort it. The Jenvey linkage is very good BTW
Posted: Thu Apr 14, 2011 12:51 pm |
Is the linkage adjustable to allow for the cable pull of various throttle pedals? I'm trying to work out if the levers on my bodies will need changing. How is the Jenvey cable held on the pedal or linkage as surely only one end has the barrel end thing...
Posted: Thu Apr 14, 2011 1:13 pm |
will get you a picture in the morning mate
Posted: Thu Apr 14, 2011 2:32 pm |
Thanks Mac.
This is my current set up. There are holes where the little adjustable rod on the linkage could maybe attach to.
Posted: Thu Apr 14, 2011 3:17 pm |
That is a terrible bracket.... we can do better than that
Posted: Fri Apr 15, 2011 1:40 am |
It does look rough doesn't it. Longmans used something similar though.
Posted: Fri Apr 15, 2011 3:40 am |
i love this project..... good work edward
Posted: Fri Apr 15, 2011 1:41 pm |
here you go mate
Posted: Fri Apr 15, 2011 3:52 pm |
Thank you. So from what I can see the levers on the bodies do look a bit different to mine.
Posted: Sat Apr 16, 2011 12:29 am |
hard to get a close up really but this is a bit closer
