Forums › Tuning, Modification & Legal › Project Cars › Project sleeper |
Posted: Sat Apr 03, 2010 4:15 am |
macj wrote: |
Pipercross panel filter part no. PP1621...£34.11 inc vat
Well.....its a start |
Over 200bhp is possible out of these engines
Posted: Sat Apr 03, 2010 4:55 am |
macj wrote: |
Might invest in a K&N panel filter only because it can be cleaned...
Geoff wrote: |
Over 200bhp is possible out of these engines |
I will not be doing any diesel tuning that's for sure! This one certainly has a stronger mid range than the Peugeot though!
Posted: Sat Apr 03, 2010 5:03 am |
Did a bit more fiddling today. The breather pipe was always popping off the attachment on the airbox which sometimes meant oil could be smelt inside the car. The airbox attachment is actually that off the original airscoop that sits on the standard throttle body. It was cut off the scoop and used on the new airbox. It was slightly loose in the airbox which mean't the standard hose couldn't be pushed on all the way hence it kept jumping off.
So I went on Ebay and bought some silicone tubing for less than £6. I cut the hose to release the original clip that attaches to the rocker cover.
Then I attached the hose to the original clip and the airbox attachment with a jubilee clip to make sure the hose doesn't come off.
Posted: Sat Apr 03, 2010 6:53 am |
what size is that tubing edward?? as i've been after some samco hose since day1, to go right to the head as its only half way atm
Posted: Sat Apr 03, 2010 7:02 am |
It's 13mm internal diameter. It's not Samco but does the job fine. You got any pictures as to where you want hose for?
Also does your car use an inlet air temp sensor? Mine seems to only have sensors for coolant, throttle position and the crank sensor.
Posted: Sat Apr 03, 2010 7:43 am |
I have an air temp sensor in the airbox
Posted: Sat Apr 03, 2010 8:18 am |
from the oil catch tank to the head breather as mine pipe has gone brittle so half is standard pipe and the other half is samco hose but i want the hole lot done properly lol.
you can see here
mine uses the crank,air,coolant,tps,oil temp sensors
Posted: Sat Apr 03, 2010 8:53 am |
Just get on Ebay then. For a breather pipe any brand of silicone will do.
I just can't find a air temp sensor at all on mine. Spike, where does your sit?
Can't stop taking pictures while the sun is out...
Posted: Sat Apr 03, 2010 10:03 am |
if you look closely paul its that little gray thing on the right hand side of my fuel rail, it will go in the box 'i think' im not sure i'll leave that to pug1off as they've goto move the rail back.
And nice 1 for the heads up on the hose paul i'll get some, i dont supose you could pm a link could you?
Posted: Sat Apr 03, 2010 11:38 am |
Yes I can see your sensor now. Either mine isn't fitted with one or it's nearer the inlet behind the arch liner somewhere.
I've had a couple of things from this place. Pretty quick postage too.
cgi.ebay.co.uk/13mm-1-...4399b2fe7e
Posted: Sat Apr 03, 2010 12:24 pm |
nice 1 paul, yourz is looking pristine as always.
Posted: Sun Apr 04, 2010 12:34 am |
What does your trip computer say now Edward/Spike, has there been any difference on fuel consumption?
Posted: Sun Apr 04, 2010 1:39 am |
I'm not sure what it's doing mpg wise. It runs hotter so that will mean it's using more fuel. I've not put fuel in it for 2 weeks.
Posted: Sun Apr 04, 2010 3:03 am |
Have you reset the trip computer? I know its not totally accurate, just wondered if it would notice!
Posted: Sun Apr 04, 2010 4:01 am |
It's not a multiplexed car so doesn't have one. I'm not sure one would work anyway with the way the car has been wired up. Not sure if Multiplexed cars are able to be wired the same as mine.
I always thought the original sensors had to keep being used in order to fool the original ECU into thinking it was still controlling the engine. On mine all the redundant stuff has been disconnected and the plugs can be seen in the first picture on the previous page. Disconnecting stuff would put the ECU light on so mine has had the bulb removed.
The original ECU now just measures coolant temperature for the guage and oil temperature. Another coolant sensor is fitted for the new ECU to read. I guess the original flywheel sensor still sends the signal via the ECU for the rev counter too.
My car uses the original flywheel sensor for the new ECU too. Longmans used a separate trigger wheel and crank sensor but that might just have been because of the EFi ECU they used. .
