Latest: elelectricistadeMateo
Overall: 17127
Online Now [68]:
Visitors: 66
Members: 1
Today: 4212
Total: 100402441
Forums › The Car › 206 Problems › Stereo Wiring with BSI (2003 206)
RyanC206
PostPosted: Sun Mar 17, 2013 2:59 pm Up
Hi all.
New to the forum.
I am looking at acquiring a 206 Quicksilver 2003.
With regards to stereo wiring for an aftermarket unit, do I need the correct ISO adapter that comes with the wiring to connect to a 12v power output, such as ciggie lighter?
broadblaster
PostPosted: Sun Mar 17, 2013 3:13 pm Up
if you look in the I.C.E section it will tell you what harness you will need mate.
autoleads pc99-x44 for multiplex main loom then
pc99-alp
pc99-son
pc99-ken
and so on depending on make of new H/U for the "control stalk" work.
on a back road playing
RyanC206
PostPosted: Sun Mar 17, 2013 3:52 pm Up
Cheers mate... learning my way around. Appreciate that!
broadblaster
PostPosted: Sun Mar 17, 2013 3:56 pm Up
no probs mate only thing i will add is i had problems getting the autoleads to work on my 180 so i used the connects2 lead but can't rember the part number for it. haveing said that most on here have used the autoleads with no problems
RyanC206
PostPosted: Sun Mar 17, 2013 4:11 pm Up
Reading through a few pages... if I get a stalk adapter, will that then just cause the stereo to have no issues as it will work with the bsi correctly?
broadblaster
PostPosted: Sun Mar 17, 2013 4:13 pm Up
yes that is correct its just plug and play and all should work fine.
RyanC206
PostPosted: Sun Mar 17, 2013 4:14 pm Up
Appreciate the help mate.
broadblaster
PostPosted: Sun Mar 17, 2013 4:16 pm Up
hey we all need help from time to time and thats the idea of forums to help us all out.
PostPosted: Mon Mar 18, 2013 6:00 am Up
All the stalk adapter does is to make the factory-fitted stalk cotrol the HU as it should. (I've fitted an autoleads one and it works perfectly 2 years now).
It does not make a difference to the BSI which still see's an error communicating with the stereo but it makes no difference anyway.
Also, it will no-longer display program information on the MFD which doesn't matter because you can see it on the HU display.
