Latest: heikkisj
Overall: 17126
Online Now [79]:
Visitors: 78
Today: 11348
Total: 100247656
Forums › The Car › 206 Problems › engine light came on...then off again
chris_h
PostPosted: Thu Mar 28, 2013 1:00 pm Up
Just left work and went up the road and the engine light came on . I drove to the lights, turned the engine off and on again quickly, and it was still on.
I went a further 7 miles and turned the engine off for about 4 minutes and the light didn't relight like it did previously....
The car drove normal and no obvious problems. acceleration was slow which is perfectly normal for the 1.1.
Seriously though it got me worried! any one else has this issue?
PostPosted: Thu Mar 28, 2013 1:07 pm Up
Something somewhere might be wrong...it might have stored the error in the ECU. Might be worth getting it plugged in to give you a clue if it's something you can act upon now.
chris_h
PostPosted: Thu Mar 28, 2013 1:14 pm Up
Fortunately it is going in to a friend on Saturday for a new clutch, with any luck he may have a laptop to hand which can help.
these 206's are a little unreliable for my taste....might selling after this clutch
Mine is blue.
PostPosted: Thu Mar 28, 2013 1:28 pm Up
All depends how it has been looked after. Perfectly reliable cars.
chris_h
PostPosted: Thu Mar 28, 2013 1:36 pm Up
I throw money at it, obviously there are worse cars but i feel £170 to change an indicator stalk is a little OTT. Other parts are pricey too, but thats another tale for another day.
I do like the rear suspension though, easier to change than other cars
PostPosted: Thu Mar 28, 2013 2:01 pm Up
I thought all the parts were cheap.
Tolkienfan001
PostPosted: Thu Mar 28, 2013 2:07 pm Up
Trade Rating: +13
I got mine for £95 you were ripped off
2005 1.4 16v Sport
Check out my 206 here!
chris_h
PostPosted: Thu Mar 28, 2013 4:45 pm Up
For a brand new comms 2000 unit? 95 quid seems a little on the cheap side. Anyway I never said I had replaced it, simply it is expensive too replace, not got that sort of money yet.
chris_h
PostPosted: Mon Apr 01, 2013 6:47 am Up
Ok just had the code checked and it is p0202
relating to the injector on cylinder 2, usual signs include and poor acceleration (none I experienced).
I will wait to see if the code returns and forward a solution
Mine is blue.
Tolkienfan001
PostPosted: Mon Apr 01, 2013 6:49 am Up
Trade Rating: +13
Got it from ECP with a discount code Smile
2005 1.4 16v Sport
PostPosted: Mon Apr 01, 2013 7:49 am Up
+1
-1
Smile
PostPosted: Mon Apr 01, 2013 10:42 am Up
I agree! What He Said
The 206 I've owned since 2005 has been the most reliable car I've had so far.
Doesn't go wrong & easy / cheap to service.
We see the same at work with the forklifts, if there looked after correctly ( which they are where I am ) you very rarely get any breakdowns.
