Latest: heikkisj
Overall: 17126
Online Now [128]:
Visitors: 127
Today: 9455
Total: 100245772
Forums › The Car › 206 Problems › problems starting and reving at 2000 and cutting out help!
ki789
PostPosted: Mon Apr 01, 2013 7:45 am Up
not sure if i have posted this right as don't come on here a lot but here goes...
My pug 206 has been having problems starting , the starting motor is running but the car does not turn over, it starts eventually after about 6 attempts but after it has started it revs at 2000 and sometimes whilst driving the car can even cut out because the revs suddenly go low.
Also I checked the water yesterday and there's light brown sludge at the top, i don't think its oil only because I cannot see a rainbow effect in the water but it could be.
I'm a girl and no good with cars so any info on this would help , i will eventually getting into a garage when i've the money to get it sorted,
thanks in advance x
Smile
PostPosted: Mon Apr 01, 2013 1:21 pm Up
Well to fix the starting problem,take a look a this link,it will show you how to fix it
www.206info.co.uk/Foru...46523.html
and about the coolant color,check your engine oil,and see it's color,if it's creamy color,then you have coolant mixed with engine oil,which means a head gasket job,if all is well,and the oil color is normal,then i recommend that you do a coolant flush,and refill it with antifreeze ,and this way things will get better for u,if you need any help ,let me know,good luck.
