Online Now [1013]:
Visitors: 1013
Today: 109794
Total: 152510846
Forums › The Car › 206 Problems › front wishbones
front wishbones
daykes1
PostPosted: Tue Apr 02, 2013 9:19 am Up
Does anybody find the front suspension on a 206 'weak'? In particular the ball joint in the wishbones?
As far as Im aware, you can't replace the ball joint on its own & a new wishbone is around £60 each & then the cost of fitting. I wouldnt mind paying a premium (within reason) IF they would last longer than 6 months!! (Ive tried eurocar parts, gsf, tm factors & ebay.)
Just wondered if anybody knows any mods to strengthen that joint? Can the ball joint be removed? & then a poly bush put in instead?
Tolkienfan001
PostPosted: Tue Apr 02, 2013 9:52 am Up
Trade Rating: +13
Think people recommend original peugeot ones as they last longer than aftermarket cheaper ones?
2005 1.4 16v Sport
Check out my 206 here!
Lecktorious
PostPosted: Tue Apr 02, 2013 9:55 am Up
Trade Rating: +59
Use an OEM arm. They are usually around the same price as a motor factors.
'98 Nile Blue 306 GTi 6
daykes1
PostPosted: Tue Apr 02, 2013 10:10 am Up
Just spoke to local Peugeot dealer & they want £126 EACH!!
PostPosted: Tue Apr 02, 2013 11:22 am Up
That's a bargain Wink
My wishbones where last changed back in 2005 / 80k + miles ago under the Peugeot 3 year manufacturer's warranty, just shows genuine parts are worth it Wink
PostPosted: Tue Apr 02, 2013 11:41 am Up
Or try the Lemforder arms from Euro Car Parts.
daykes1
PostPosted: Wed Apr 03, 2013 4:27 am Up
Cheers everyone, Yeah I think your right is got to be OEM or Lemforder.
MrBSI: Is your car completely standard? Do you have decent roads in your area?
PostPosted: Wed Apr 03, 2013 4:57 am Up
I think MrB's is completely standard, his roads are the same as everyone else's, but he just doesn't drive around like a complete cοck.
...only kidding. Smile
OEM all the way.
chris_h
PostPosted: Wed Apr 03, 2013 7:18 am Up
my car was 10 years old until new wish bones were needed....the original ones
Mine is blue.
Mr-Tigger
PostPosted: Wed Apr 03, 2013 11:52 am Up
if you browse about you can grab some Meyle HD for most 206's for £60 each Wink
PostPosted: Thu Apr 04, 2013 5:57 pm Up
It will help them last longer if you carefully remove the spring clips and rubber boot. Add extra silicon grease (some manufacturers are very stingy only using a tiny, tiny bit and some don't put any in!) then refit the boot and spring clip. Be warned that the clips can split the boots when refitting though Peugeot do list just boots so if you split one you can buy a replacement boot for a few pounds.
You may also find that the metal heat shield between the ball joint and brake disc is missing. This lets the heat from the brake disc overheat the ball joint also speeding up wear.
Andy_206
PostPosted: Thu Apr 04, 2013 6:16 pm Up
Both 206s I've had have needed new wishbones..
So in answer to your question yeh I think there pretty s**t
Audi A3 sport
PostPosted: Fri Apr 05, 2013 4:25 am Up
Most cars these days seem to wear front suspension wishbones. Just be happy you dont have an Alfa 147 / 156 / GT. The double wishbone front suspension is the same on all these models and everything (bottom wishbones, top wishbones, drop links and anti-roll bars) either creaks or clunks within 30,000 miles and unlike the 206 most (all) the bolts will be siezed.
usher
PostPosted: Fri Apr 05, 2013 5:15 am Up
mine were about 70k miles and 12 years old only clunky not knackered
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Fri Apr 05, 2013 6:11 am Up
This is an interesting point.
I've had massive problems with those. 50% chance they rattle on me very badly so I take them off.
Initialy they were missing and I ordered nice new ones (genuine too).
Even though I believe fitted properly, one side would rattle away to the point you can hear it whilist driving.
This happened on both 206 I've fitted them and I still don't get it.
