Latest: elelectricistadeMateo
Overall: 17127
Online Now [62]:
Visitors: 61
Today: 4712
Total: 100402940
Forums › The Car › 206 Problems › Aerial part name
Aerial part name
Razor34
PostPosted: Sun Apr 21, 2013 9:11 am Up
Hi,
I own a Peugeot 206 1.4 GLX 02 Plate and in the last month or two have started experiencing major problems with loss of radio signal. I recently got rid of the standard pug head unit (old tape deck) and have put in a Phillips but this has made no difference. The aerial connector at the back is fully plugged in and ok. The only thing I can think of as the aerial itself is also but there is a circuit board round plug which is attached to the cable that is then held in place by a nut at the front of the car underneath the courtesy light at the front and looks a bit corroded.
Could this be the problem and if so what is it called and any ideas on cost?
Thank you
Ray
Razor34
PostPosted: Mon Apr 22, 2013 4:38 am Up
Anyone??
Ray
Razor34
PostPosted: Mon Apr 22, 2013 5:22 am Up
OK spoke to Peugeot as I found the part number on Peugeot Service Box 6561 72 but apparently it is no longer supplied. Does anyone have one for sale that I can buy???
Ray
PostPosted: Mon Apr 22, 2013 5:30 am Up
Correct, I just checked & its NFP.
Ebay, scrapyard, someone breaking a 206 on here.
Razor34
PostPosted: Mon Apr 22, 2013 5:57 am Up
Cheers Mate
Ray
