Latest: heikkisj
Overall: 17126
Online Now [175]:
Visitors: 174
Today: 20479
Total: 100353440
Forums › The Car › 206 Problems › Power steering pipe!
Yorkie
PostPosted: Sun May 26, 2013 5:15 am Up
Hi folks, got a power steering fluid leak from the alloy pipe at the side of the radiator. I've taken it off and its the one that goes from the resevoir, down round the horn on the crossmember and then back up to connect to the one that goes across the top of the radiator. Do i need to replace it with the same original pipe or could i just use a length if good quality braided hose. The car is a 1.4 hdi cheers !
PostPosted: Sun May 26, 2013 7:12 am Up
You can get from scrapyard for this and it's better.
