Latest: lio94
Overall: 17181
Online Now [321]:
Visitors: 320
Today: 73838
Total: 142024315
Forums › The Car › Request a how-to › Replacing the Gear Linkage
Forum IndexRequest a how-to
20Drift
PostPosted: Thu Apr 11, 2013 12:31 pm Reply with quote Up
Hi Guys,
I've got a 206 LX 1.4 Petrol, and the gear stick has become a bit wobbly/jelly like, (there's a more-than-normal amount of play in the gear stick, indicating the rubbers have worn).
I've been looking at a replacement, but wanted to know if anyone's got a how-to or rough guide about how I'd go about changing the gear linkage?
Many thanks in advance!
Arrow
PostPosted: Thu Apr 11, 2013 1:01 pm Reply with quote Up
One of the simplest things to change, only thing you need to remove to gain access is the pipe from the throttle body to the airbox. Then they just pull on and off, but you will probably need something like a pry bar to pop them off, and a pair of mole grips or something similar to pop the new ones in.
20Drift
PostPosted: Thu Apr 11, 2013 1:17 pm Reply with quote Up
Cheers for the speedy response!
I'm a bit of a newbie when it comes to fiddling around in the engine bay/underside of the car - I work mainly in audio systems and ICE.
Where abouts is the throttle body/airbox pipe?
PostPosted: Thu Apr 11, 2013 1:21 pm Reply with quote Up
You'll see it straight away, sits between the side of the engine and the battery.
20Drift
PostPosted: Thu Apr 11, 2013 1:28 pm Reply with quote Up
I see it! Thanks Lee. Also, should I leave the car in gear or neutral when carrying out the change?
PostPosted: Thu Apr 11, 2013 1:31 pm Reply with quote Up
leave it in neutral and you'll be fine, just try not to let the ball pop out on the linkage.
southwestchap
PostPosted: Fri Apr 12, 2013 5:33 am Reply with quote Up
they can be absolute pigs to do as ive been doing them recently. 13mm and 14mm spanner seem to be a half decent way to pop them off (lever the 13mm against the 14mm)
else have a pry bar and catch the edge of the linkage and pop it that way off. youll see how it works when your looking at it.
tsotd
PostPosted: Sat Apr 13, 2013 4:36 am Reply with quote Up
do the linkages 1 at a time so you dont get mixed up with which one goes where
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
gtijames22
PostPosted: Tue Apr 16, 2013 1:35 pm Reply with quote Up
does the 180 have the same linkages or is there a different setup for these?
thanks
GTI 180 JIM
PostPosted: Tue Apr 16, 2013 2:46 pm Reply with quote Up
thanks
180 Uses cables not rods so that it clears the exhaust manifold.
PostPosted: Tue Apr 16, 2013 3:01 pm Reply with quote Up
I believe thei'r both the same.
Mind you don't break off the balls when you pull them. Cool
HarryQDG
PostPosted: Fri Mar 28, 2014 6:36 pm Reply with quote Up
Does the 206 1.4 HDI replace the same as above? Would like details on complete removal at gear shift end too please?
Thanks.
  Quick Reply
Username:
Message:
Quote the last message
