Online Now [977]:
Visitors: 977
Today: 151775
Total: 149548918
Forums › The Car › 206 Talk › 1.4 hdi, how loud
1.4 hdi, how loud
Forum Index › 206 Talk
bikesforme
PostPosted: Mon Apr 08, 2013 5:07 am Up
My partrners 1.4 hdi seems to be making that dissel tapping noise much louder then when she brought it. Its seems to be coming from drivers side top of engine. I have flushed engine and put fresh oil in, but it still sounds loud, anyone got a 1.4 hdi and can tell me if its normal. Thanks
TelaKeppi
PostPosted: Mon Apr 08, 2013 10:27 am Up
Mine sounds like this plus a little aux belt whine when cold.
There's 3 things that can make the sound, most obvious and easy to check is bottom pulley. This has a distinct metallic clank. Then here's a leaking injector, that makes a chuffing sound. And then clogged tappets, when you rev the engine and the oil pressure (or temperature) gets high enough the tapping will stop. This is easy to notice when gaining speed from standstill with cold engine.
206 1.4 HDi
Fifer
PostPosted: Fri Apr 12, 2013 1:15 pm Up
Tappets are really obvious. Mine stops about 3000 rpm as the pressure builds and the difference in sound is really noticable. If it is this then you can try the tappetcleaner additive (made mine sound better but not completely gone). I was goingto change mine out untill I saw the price of new ones as the car only needs to run another year then its going.
1.4hdi 02
TelaKeppi
PostPosted: Fri Apr 12, 2013 3:27 pm Up
Actually the tappets are really cheap. I got mine from here, same as the original PSA part.
206 1.4 HDi
bikesforme
PostPosted: Tue Apr 16, 2013 7:26 am Up
Its not bottom pulley, noise coming from top, might be noisy injector
sicskate
PostPosted: Tue Apr 16, 2013 9:12 am Up
Trade Rating: +13
When you say tappets, I think you mean the hydrolic lifters?
Mine make a noise until 3k, then disappear.
Think i'll do mine soon, only £50 for 8.
Does anyone know if the cam belt and cam need to be removed?
307 1.4hdi Smile
TelaKeppi
PostPosted: Tue Apr 16, 2013 11:11 am Up
Yes, they have to be removed.
206 1.4 HDi
