Posted: Sun Apr 14, 2013 8:36 am |
Trade Rating: +13
I keep losing caps.
Either elves are taking them or they are so old now they fit too loosely.
I am going to guess it is the second reason.
So should I buy them from eBay or peugeot?
Does anyone know the price for a set from peugeot?
Also on eBay there are 17mm or 19mm. Which ones do I need please?
Posted: Sun Apr 14, 2013 8:41 am |
I'd probably say eBay maybe cheaper due to them not having to be Peugeot specific, you can just by generic ones.
17mm or 19mm.....depends on the size of your wheel bolts.
Posted: Sun Apr 14, 2013 8:52 am |
Trade Rating: +13
Ok thanks I will measure and order on eBay. Thanks for the quick response. Much appreciated.
Posted: Sun Apr 14, 2013 9:02 am |
Pm'd
Posted: Sun Apr 14, 2013 9:13 am |
My 206 uses 19mm bolts.
Posted: Sun Apr 14, 2013 9:15 am |
Trade Rating: +13
Edward wrote: |
My 206 uses 19mm bolts. |
Alloys?
Posted: Sun Apr 14, 2013 10:32 am |
Tolkienfan001 wrote: |
Edward wrote: |
Alloys? |
Mine are 19mm alloy bolts to.
Posted: Sun Apr 14, 2013 10:36 am |
Trade Rating: +13
Thank you guys I have just measured and mine are 19mm
Posted: Sun Apr 14, 2013 10:47 am |
You can get 17mm and 19mm alloy wheel bolts.
If you go for ebay ones, I hope yours are better than the ones I bought ... far too loose and keep dropping off. Not helped I guess by the cr@p road surfaces we have to put up with.
Posted: Sun Apr 14, 2013 10:53 am |
Trade Rating: +13
gazza82 wrote: |
If you go for ebay ones, I hope yours are better than the ones I bought ... far too loose and keep dropping off. Not helped I guess by the cr@p road surfaces we have to put up with. |
Yea lets not get started on the condition of the roads!
I have just had my alloys referbed and the way I am dodging pot holes, at some point I will get pulled over! I have been driving for over 12 yrs and have never been pulled over.
I feel my first time is close!
Posted: Sun Apr 14, 2013 11:40 am |
The 207CC had 17mm bolts. If the covers are loose then but a small bit of paper between bolt head and cover.
Posted: Sun Apr 14, 2013 11:53 am |
Trade Rating: +13
Edward wrote: |
The 207CC had 17mm bolts. If the covers are loose then but a small bit of paper between bolt head and cover. |
Might try that. Thanks
Posted: Tue Apr 16, 2013 5:44 am |
Mrs' 206 has 17mm bolts also from factory. It's a 2008 1.4i.
Posted: Mon Apr 22, 2013 8:30 am |
there only £1.50 or so each from dealer, i had to get 2 a while back
