Posted: Sat Apr 27, 2013 10:31 am |
Does anyone have a how-to/guidance on changing the head gasket of a 1.4 16v sport (ET3J4)?
Would be very much appreciated.
Posted: Sat Apr 27, 2013 11:16 am |
Give me a couple of days and I will post up a full guide
| Team Impossible Possible
Posted: Sat Apr 27, 2013 11:49 am |
Amazing, thanks very much!
Posted: Sat Apr 27, 2013 12:39 pm |
Addaz wrote: |
Give me a couple of days and I will post up a full guide |
What are you doing with one of these engines?!!
Posted: Sat Apr 27, 2013 5:30 pm |
Im not yet mate
Posted: Sat Sep 07, 2013 3:32 am |
Does anyone know what size/type of socket to use on the head gasket bolts? They are a 6 pointed star shape.
Posted: Sat Sep 07, 2013 4:18 am |
If you can't spot a torx head on a bolt you're out of your depth doing a head gasket change. I would guess you don't have a torque wrench either?
Posted: Sat Sep 07, 2013 4:40 am |
There is a good guide in the Haynes manual
Posted: Sat Sep 07, 2013 5:06 am |
I can only see the bolt length to check for and torques in Haynes.
Posted: Sat Sep 07, 2013 8:30 am |
You need to change the bolts as there stretch type i.e. you can only use them once.
Posted: Wed Sep 11, 2013 10:49 am |
adzar wrote: |
Does anyone know what size/type of socket to use on the head gasket bolts? They are a 6 pointed star shape. |
E-14 is the answer
Posted: Wed Sep 11, 2013 2:40 pm |
if you need a how to then you SHOULDNT be doing it!!!
Posted: Thu Sep 26, 2013 10:34 am |
Question for re-assembly:
The haines manual gives the inlet sprocket retaining bolt torque as:
stage 1 = 20Nm
stage 2 = 60Nm
What is the procedure for tightening a single bolt in two stages?
There doesnt appear to be any specific reference to the two torques in the manual as there was for the head gasket bolts for instance.
