Forums › The Car › 206 Talk › Radiator Bushes... ? |
Posted: Tue Apr 30, 2013 6:26 am |
Whilst doing a service on the old girl over the weekend, I noticed that the radiator appears to lack any bushes.
I take it it is actually meant to have some?
If so, anyone know the part no. for them?
Posted: Tue Apr 30, 2013 7:03 am |
The little prongs on the radiator have rubber bushes round them.
Posted: Wed May 01, 2013 8:29 am |
I thought as much! Will try and see if I can find out which ones they are.
