Posted: Thu May 02, 2013 9:24 am |
Dad has a set of 4 spoke rs rims on his mk2 escort and wants to go for a bigger sized rim. There a 13 inch rim and I love the look of them. What I want to know is how would I be able to get them to fit. I don't want paragraphs telling me what offset they are or all this jibber jabber, all I want to know is if I use hub adaptors, lathe were the centre caps go or what? And yes I do realise 13 is tiny but I want that low and slow look
Posted: Thu May 02, 2013 10:33 am |
Sure its just 10mm spacers
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Thu May 02, 2013 10:48 am |
Think Uz is the best person to help you out with the answer, since he's the resident wheel w**re.
RS alloys are great looking wheels, too many of them were ruined by the white paint though.
Posted: Thu May 02, 2013 1:39 pm |
You called Neil..?
What you need is...
63.4mm to 65.1mm 20mm hubcentric spacers.
Posted: Thu May 02, 2013 4:56 pm |
Im getting the car lowered on saturday so next week if i get the spacers i'll fit them and take pics
Posted: Fri May 03, 2013 3:03 am |
Depending on what 206 youve got the 13" RS wheels wont fit over the brakes. Your brake setup needs to be a 247mm setup for them to fit and even then itll be extremely extremely touch and go.
Posted: Fri May 03, 2013 4:33 am |
Posted: Fri May 03, 2013 11:10 am |
Also if your interested all i needed was 2 of the spacers so you can have the other two for £40.00 posted?
You will need the bolts to bolt them on or i have some car bolts with the heads cut off heads
you can have for free.
cheers
