Latest: Mr-Koekwaus
Overall: 17125
Online Now [308]:
Visitors: 307
Today: 61204
Total: 99566414
Forums › The Car › 206 Talk › Pug 206 Xsi 1.6 16v - Millage question
Achillez
PostPosted: Thu Oct 25, 2012 6:46 pm Up
Hello all, I'm new to this forums and I'm hoping someone can help me.
I've got a 03 xsi 206, 1.6 16v ( 110BHP if I remember correctly ) and I think there's something wrong, With a full tank of fuel I only get 260-280 miles, I dont hammer the car at all, I drive normal, pretty much always in 5th, stick to speed limits. My clock on the dashboard says I'm getting 40 to the gallon, but when I work it out I'm getting 25 miles to the gallon which is shocking, I do have a little hole in the exhaust somewhere but I dont think this would be effecting the car that much.
Can anyone else out there with a 206 xsi tell me how much they are getting with a full tank of fuel?
roscoe
PostPosted: Thu Oct 25, 2012 7:42 pm Up
I'm not a 206 owner anymore but something is seriously wrong there. I get about 210 miles off £20 and mines a 3 litre
Used to own the 206 pictured above
M sport BMW E90 - Gone Sad
Now own Audi A5 Sline Smile
Achillez
PostPosted: Fri Oct 26, 2012 2:32 am Up
At the moment I've done 134 miles and I'm under half way point. Is this a common fault or?
roscoe
PostPosted: Fri Oct 26, 2012 3:04 am Up
Maybe just needs a good service. I had a 1.1 206 was doing 50 mile a day round trip costing me £20 every 2 days one of the reason I had to sell it.
Was a little better after a service.
-Dave-
PostPosted: Fri Oct 26, 2012 5:15 am Up
Trade Rating: +36
I get better than that but not by much. I did a 500 mile round trip recently and it took a tank and a quarter. That was half night time driving aswell. One o the reasons it's going and I'm getting a diesel. I will also point out my car is serviced regular and looked after.
Ex 206 Owner.
Ali_H
PostPosted: Fri Oct 26, 2012 5:24 am Up
I get that on my 180.
kurtis wrote:
Uz
PostPosted: Fri Oct 26, 2012 5:37 am Up
I used to get double that driving every day to Birmingham and back in my XSI with a tank brimmed on a monday morning. Used to last me till end Friday morning.
Achillez
PostPosted: Fri Oct 26, 2012 7:09 am Up
My car is standard, not chipped or any mods. What could cause this and how can i find the fault, I had a service last week and it changed nothing. I'd hate to see what I'd get if I drove like an idiot.
I don't really wanna take it to a garage and they replace parts and me having to spend money when it hasnt solved the issue, hence why id like to find the problem myself.
Could it be that I need to clean the injectors? Should I put some injector cleaner or whatever u call it in my tank?
I'd like to thank everyone that has replied so far.
PostPosted: Fri Oct 26, 2012 7:31 am Up
What maths are you using? Shouldn't be driving round in 5th all the time either!
Achillez
PostPosted: Fri Oct 26, 2012 7:55 am Up
280 miles ÷ 11 gallon, = 25 to the gallon, my clock on dashboard says I'm doing 40 so I should get 440 miles. And yes I have reset my clocks when I fill my tank to the top.
PostPosted: Fri Oct 26, 2012 8:31 am Up
How have you worked the litre to gallon ratio out? Imperial gallon or US gallon?
11 gallons is 50.05 litres. The tank holds 50 litres. Your calculations could be out.
wifes206
PostPosted: Fri Oct 26, 2012 8:56 am Up
it little over 50 litres but not even 50.01 so I'd work it out to 11gallons = 50litre
So your mpg = 25.45
Something's wrong somewhere that seems low, but not had a
petrol car in a long time
206 2.0hdi(04)
PostPosted: Fri Oct 26, 2012 10:03 am Up
you never mention what road did you drive mostly.
Quarmbo
PostPosted: Fri Oct 26, 2012 10:29 am Up
Don't drive in 5th all the time. You're engine will struggle and fuel consumption will be worse.
Ford SportGay-A
robclowes
PostPosted: Fri Oct 26, 2012 10:38 am Up
i travel 88 miles a day 5 days a week and get about 42-44 mpg out of my xsi. Most of my driving is on motorway. I get about 420-440 per £60
206 1.6 xsi
