Latest: dreyfalon
Overall: 17121
Online Now [494]:
Visitors: 493
Today: 65742
Total: 97365743
Forums › The Car › 206 Talk › Spare Wheel Cage/Bolt
Tam80
PostPosted: Fri Aug 19, 2011 7:52 am Up
Anybody Any Ideas Much These Are From Stealers ?
Cheers Thumb Up
206/GT/GTI
Abzynthe
PostPosted: Fri Aug 19, 2011 7:53 am Up
East Area Rep - Abzynthe
Are There No Scrappies Near You?
Im sure it would be alot cheaper Smile
00budham00
PostPosted: Fri Aug 19, 2011 8:12 am Up
bnq buy a long bolt washer and a piece of metal plate make your own.... or What He Said
PostPosted: Fri Aug 19, 2011 8:19 am Up
There cheap enough to buy new from any Peugeot / Citroen main dealer, part is normally in stock as they sell plenty due to idiots not greasing them up.
Tam80
PostPosted: Fri Aug 19, 2011 10:30 am Up
no cage on my 206 when i got it...just a seized bolt that was cable tied to stop it rattling...
was at scrappys earlier but no chance of getting 1 off due to rotten bolts being seized
picked up a spare with brand new tyre thats never seen the road (unless from the cage counts lol)..but had to mangle the cage to get wheel out
will nip to stealers and get the cage/bolt up then Thumb Up
so is the citroen cage the same fit then ???
cheers guys Wink
206/GT/GTI
PostPosted: Fri Aug 19, 2011 2:41 pm Up
i am still trying to grind that bolt off Sad
PostPosted: Fri Aug 19, 2011 4:01 pm Up
I have one from my car Smile Make me an offer
Lecktorious
PostPosted: Fri Aug 19, 2011 4:08 pm Up
Trade Rating: +59
CRADLE 7603 Q4: £42.52 INC. VAT
'98 Nile Blue 306 GTi 6
PostPosted: Sat Aug 20, 2011 5:57 am Up
Moral of this thread is:
If you own a PSA Peugeot / Citroen with a spare slung under the boot in a cradle then its a good idea to grease up the cradle bolt & hook if you want to be able to use your spare wheel in the future.
Copper grease FTW Cool
PostPosted: Sat Aug 20, 2011 6:33 am Up
I greased mine and every week I had to tighten the bolt. For the past six years the wheel has lived in the boot. Much safer and cleaner that way.
PostPosted: Sat Aug 20, 2011 6:37 am Up
your case is different Laughing
can't even find a dust or rust on your gti Cool
Tam80
PostPosted: Sat Aug 20, 2011 2:04 pm Up
pm sent Wink
206/GT/GTI
PostPosted: Sat Aug 20, 2011 2:06 pm Up
I have one, but I use it as a trailer hitch pin for the ride on lawn-mower Laughing
Majid
PostPosted: Sun May 12, 2013 7:20 am Up
onWill bolt croppers cut the bolt?
Peugeot 206, 1.6, 16 valve
2003
