Posted: Fri Aug 19, 2011 7:52 am |
Spare Wheel Cage/Bolt
Anybody Any Ideas Much These Are From Stealers ?
Cheers
Posted: Fri Aug 19, 2011 7:53 am |
Are There No Scrappies Near You?
Im sure it would be alot cheaper
Posted: Fri Aug 19, 2011 8:12 am |
bnq buy a long bolt washer and a piece of metal plate make your own.... or
Posted: Fri Aug 19, 2011 8:19 am |
There cheap enough to buy new from any Peugeot / Citroen main dealer, part is normally in stock as they sell plenty due to idiots not greasing them up.
Posted: Fri Aug 19, 2011 10:30 am |
no cage on my 206 when i got it...just a seized bolt that was cable tied to stop it rattling...
was at scrappys earlier but no chance of getting 1 off due to rotten bolts being seized
picked up a spare with brand new tyre thats never seen the road (unless from the cage counts lol)..but had to mangle the cage to get wheel out
will nip to stealers and get the cage/bolt up then
so is the citroen cage the same fit then ???
cheers guys
Posted: Fri Aug 19, 2011 2:41 pm |
i am still trying to grind that bolt off
Posted: Fri Aug 19, 2011 4:01 pm |
I have one from my car Make me an offer
Posted: Fri Aug 19, 2011 4:08 pm |
Trade Rating: +59
CRADLE 7603 Q4: £42.52 INC. VAT
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Aug 20, 2011 5:57 am |
Moral of this thread is:
If you own a PSA Peugeot / Citroen with a spare slung under the boot in a cradle then its a good idea to grease up the cradle bolt & hook if you want to be able to use your spare wheel in the future.
Copper grease FTW
Posted: Sat Aug 20, 2011 6:33 am |
I greased mine and every week I had to tighten the bolt. For the past six years the wheel has lived in the boot. Much safer and cleaner that way.
Posted: Sat Aug 20, 2011 6:37 am |
Edward wrote: |
I greased mine and every week I had to tighten the bolt. For the past six years the wheel has lived in the boot. Much safer and cleaner that way. |
your case is different
can't even find a dust or rust on your gti
Posted: Sat Aug 20, 2011 2:04 pm |
tomd0801754 wrote: |
I have one from my car Make me an offer |
pm sent
Posted: Sat Aug 20, 2011 2:06 pm |
I have one, but I use it as a trailer hitch pin for the ride on lawn-mower
Posted: Sun May 12, 2013 7:20 am |
onWill bolt croppers cut the bolt?
| Peugeot 206, 1.6, 16 valve
2003 | |
