Latest: Mr-Koekwaus
Overall: 17125
Online Now [447]:
Visitors: 446
Today: 66223
Total: 99491697
Forums › The Car › 206 Problems › Horror on Motorway.. Spring snaps
Daytona600
PostPosted: Mon May 13, 2013 10:54 am Up
i had bought some spax shocks and springs a couple of years ago off here. last week doing 70 the car suddenly lost control and in mid lane it decelerated in seconds. Luckily I was able to pull onto hard shoulder.
The spring had corroded and snapped. It came over the support on the strut and clamped down on the wheel. It was towed home for £150.. ouch Confused
When I was able to inspect the passenger side found the spring had also corroded and was hanging loosely.
[/img]
Question: Do you advise I just get the lowering springs 40mm spax for the strut or buy a whole new kit? the car is lowered back end via torsion bar
If a new setup what would you recommend bearing in mind cost. Anyone recommend anything for around the £250 mark? Or any ideas on what I can do next to stay safe and keep costs down.
Would be really appreciated.
ITEAM
PostPosted: Mon May 13, 2013 11:20 am Up
Jesus... take it they weren't new? That's some serious wear
Just get new springs and dampers, they whole lot looks buggered
For £250 I would get a second hand B8 + faulkner / eibach setup but if you want to buy new you're limited to stuff like apex, spax (again) etc - I just consider them all similar in performance but probably aren't
usher
PostPosted: Mon May 13, 2013 12:43 pm Up
i did wonder about the quality of mine when they were removed after 4 years, they looked worce than the origional ones of 10 years
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Mon May 13, 2013 12:51 pm Up
brand new kit is the best thing to do,you are lucky that you have not had a car accident Smile
Daytona600
PostPosted: Mon May 13, 2013 1:28 pm Up
Yep. Very lucky. The fact that the spring on both sides had shattered was the most puzzling. Both had rotted away. I notice how Spax just give 2 years warranty whilst Apex for example give five years. these were just 1 year when I got them 4 years ago so in total 5 years use.
Cheers for recommendation of 2nd hand. Very hard to find good used suspension parts though for the 1.4hdi and not much on offer on this site either at the minute.
If anyone has had good experience with the lesser brands let me know.
Many thanks in advance
ITEAM
=ZiAn=
PostPosted: Mon May 13, 2013 1:32 pm Up
One of our local Peugeot club members completely totaled his car due to a similar problem on the highway... Count yourself lucky!
ZianDesigns - Website designs
PostPosted: Mon May 13, 2013 3:06 pm Up
Both snapping at the same time. Previously unheard of except being silly over road bumps I believe. Did they really break together and at the same time for no reason while cruising on the motorway? Go on you can own up to us.
Yes they are definitely rotted but for both to go at exactly the same time, as before, is unheard of.
PostPosted: Mon May 13, 2013 3:54 pm Up
Your tyres ate looking a bit slick as well.
PostPosted: Mon May 13, 2013 3:59 pm Up
Surely heavily corroded springs would be an advisory on the MOT?
Daytona600
PostPosted: Mon May 13, 2013 4:47 pm Up
Tyres legal on one side, on the other now not legal due to spring rubbing ferociously.
And no what could I possibly be doing in a 1.4hdi van with computer equipment in the back? Its my livelihood so no way going any speed...
It may have been that once one went the other side felt the pressure.. I don't know
anyways am asking for advice on which suspension to get not play 'spot the bald tyre' Rolling Eyes
Anyone ever used these? Pro Sport S Line Suspension Kit
ITEAM
Rob2859
PostPosted: Mon May 13, 2013 7:40 pm Up
I was really impressed with my Apex springs for what I paid for them. Only heard bad things about spax.
