Online Now [294]:
Visitors: 292
Members: 1
Today: 78834
Total: 155038511
Forums › The Car › 206 Problems › Car problems
Car problems
Sarahsmith123
PostPosted: Tue May 14, 2013 10:53 am Up
Driving my car last night and all of a sudden the air bag,abs lights came on the dash with the stop light flashing and the handbrake light on. Also with a continuous beeping noise. Can anyone help? Thanks
My progress thread
www.206info.co.uk/Foru...53723.html
Tolkienfan001
PostPosted: Tue May 14, 2013 11:17 am Up
Trade Rating: +13
Ah electrical problems! Sounds like my car. It has been going mad! Continuous beeps random beeps random warning lights. The radio staying on etc etc.
Seems ok now. I replaced the gearbox earth strap / negative battery cable. Cleaned the two earth points behind the headlights, and rebooted the BSI.
Have you done any of these things? Also do you have any aftermarket electrics? Or have you changed anything electrical recently?
2005 1.4 16v Sport
Check out my 206 here!
Tolkienfan001
PostPosted: Tue May 14, 2013 11:18 am Up
Trade Rating: +13
Also may be worth having the codes read if you have not done already?
2005 1.4 16v Sport
Sarahsmith123
PostPosted: Tue May 14, 2013 11:24 am Up
No I haven't done any checks yet. And have only changed the rear lights around 2 weeks ago.
My progress thread
Sarahsmith123
PostPosted: Tue May 14, 2013 1:15 pm Up
can anyone else help? just happened to me again?
My progress thread
Tolkienfan001
PostPosted: Tue May 14, 2013 1:17 pm Up
Trade Rating: +13
Try rebooting the BSI and check the earth straps for corrosion
2005 1.4 16v Sport
Sarahsmith123
PostPosted: Tue May 14, 2013 1:22 pm Up
rebooting the BSI sounds a bit too technical for me Laughing . will check the earth straps tmorrow. thank you.
My progress thread
Tolkienfan001
PostPosted: Tue May 14, 2013 1:24 pm Up
Trade Rating: +13
Check out the BSI guide on the beginners thread.
It's basically a correct battery disconnect and reconnect procedure
2005 1.4 16v Sport
Sarahsmith123
PostPosted: Tue May 14, 2013 1:28 pm Up
thank-you.
My progress thread
Leegsi
PostPosted: Tue May 14, 2013 1:34 pm Up
Where in West Sussex are you as I have a code reader I could try for you.
Sarahsmith123
PostPosted: Tue May 14, 2013 1:40 pm Up
im in selsey,chichester Smile
My progress thread
PostPosted: Tue May 14, 2013 2:13 pm Up
I think that you have a problem with your car alternator,maybe it's over charging like have 16 Volts instead of 14 Volts,or poor charging like having 8 Volts,both cases cause such a problem.
Get a Multimeter,start the car,while you measure the battery,and see how many volts you have,it's an easy start,only take few min.
Sarahsmith123
PostPosted: Wed May 15, 2013 5:54 am Up
Thanks. Someone has Also said it could be the fan belt slipping when wet.
My progress thread
