Posted: Wed May 15, 2013 5:19 pm |
Hello,
Firstly ,I really like my 206 some times lol and have had so many things wrong with it but haven't the major funds to get a new one only fix mine,
Problem is that it's broke again and it's possibly clutch related but I'm not sure.
Firstly when I pressed the clutch to go into reverse I heard a clunk then it wouldn't go into gear.
Upon calling the garage they told me to put the car into first and turn the engine on, this resulted in the car jerking forward.
Ican just about get the car going forward but only if I put my foot down quite far which smells like I'm burning it out :S
I had a friend press down on the clutch and can see the end of the cable just above the gear box on the passenger side of the engine underneath the air intake pipe moving in and out when he was pressing it.
What the heck has gone on my car as I'm willing to get a new clutch but would like to try and avoid it if possible.
Thanks for any help
| peugeot 206 silver 1.4ltr lx | |
Posted: Thu May 16, 2013 4:13 am |
Start the car. Leave handbrake on and put in first gear. Now release the clutch pedal as if you are about to drive away.
Does the engine stall?
When the engine is idling and you press the clutch pedal, are there any noises coming from the gearbox or bell housing?
I'm thinking pressure plate or release bearing may have failed from what you have said already.
Posted: Thu May 16, 2013 6:10 am |
When i put it into first it jolts forward but doesn't seem like it wants to stall :S there's no weird noises although before the disaster it used to make a churping noise when my foot was not on the clutch, when i put my foot down on the clutch it would stop. now that noise has gone completely :S
Posted: Thu May 16, 2013 6:16 am |
It should stall. Maybe the clutch needs replacing.
Posted: Thu May 16, 2013 6:23 am |
That's the clutch bearing, it has now probably collapsed and broken apart so it will most likely be a new clutch assembly required
Posted: Thu May 16, 2013 6:28 am |
DAMN i was hoping for some news that didn't Say ''new clutch" but i guess i have to face it and book it in for a clutch replacement, although i did get a quote for £210 inc VAT from 1 place.
thanks people for helping me to confirm its demise
Posted: Thu May 16, 2013 7:01 am |
It should stall in 1st with the hand-brake firmly on that is.
Might just be the bearing but it could have damaged clutch in there as Deckchair5 said.
Posted: Thu May 16, 2013 7:20 am |
I'll bite the bullet and get the clutch replaced cant be much more to go wrong with my car now lol, its had new brakes all around, new cam belt, new water pump and thermostat, new oil filter, new petrol filter, new tyres, and now a new clutch all this is a year
Posted: Thu May 16, 2013 7:30 am |
For the price difference between a clutch kit and just the bearing, it's a no brainer to get the whole lot done.
It could be the fingers on the pressure plate that caused the bearing to fail in the first place, so cheaper to get the whole clutch done now than to have to pay another £200 for the box to come back out in another 6 months if the bearing went again.
Posted: Fri May 17, 2013 9:20 am |
what about the flywheel? could this have been damaged too? somebody mentioned it to me today
Posted: Fri May 17, 2013 9:32 am |
nemesislee wrote: |
what about the flywheel? could this have been damaged too? somebody mentioned it to me today |
Highly unlikely on a TU3 lump, there basically bulletproof.
Posted: Fri May 17, 2013 9:42 am |
Lol shame the rest ain't its annoying though as the flywheel don't seem to be that expensive im guessing its just the labour that puts it up :S
Posted: Thu May 23, 2013 10:05 am |
Just got a call from the garage that it initially was all sorted but they couldn't select any gears when the car was off the ramp. I've looked into this and all points to one part being put in the wrong way round. lol, any way found this site :
www.cartoq.com/when-to...ing-signs/
My clutch hadn't actually failed but the pressure plate teeth??? were bent out of shape which caused the problem, but i'm not to fussed so had the whole thing replaced all in for around £210 inc VAT
Posted: Thu May 23, 2013 12:41 pm |
Good to have the whole clutch assembly done, absolutely pointless messing about with anything less
The clutch pressure plate fingers bent in because the clutch thrust bearing was seizing up and scored a groove in the fingers just like a grinding wheel which weakened the fingers to the point where they just collapsed
Doesn't sound so good that the garage was incapable of putting things back together properly on a very routine job. Check if they replaced the clutch cable too as that's essential for certain types of cable as they don't ratchet back, they will only go one way to take up the slack
Posted: Fri May 24, 2013 1:54 am |
Its good you mentioned that i will have to check with them today, Im hoping they did :S
