Online Now [239]:
Visitors: 238
Today: 112938
Total: 128212639
Forums › The Car › 206 Problems › Shock absorbers.....Change both? Cost?
bondyshambles
PostPosted: Thu May 16, 2013 1:57 pm Up
So i have been having a clonking noise at low speeds on the drivers side and after taking the wheel off i saw this....
So my question is....Is it the norm to change only one or, should i change both? What sort of price should i pay for a respectable shock or are the e-bay cheap ones good enough? How long to change as in what would a garage sting me for? Or can an amateur do it easy enough?
Its a GTI 138 on a 52
Cheers in advance...
PostPosted: Thu May 16, 2013 2:21 pm Up
Avoid Ebay rubbish. Try Euro Car Parts. Not that expensive especially with the parts25 discount code.
You need to change both. Also need new nuts and bolts for hub to wishbone and hub to damper.
Need spring compressor and few other tools to do it. New drop links are always a good idea too. I'd consider new top mounts if the car has done a few miles.
bondyshambles
PostPosted: Fri May 17, 2013 1:13 pm Up
Ok thanks for the advice
PostPosted: Fri May 17, 2013 1:22 pm Up
Jesus, how big is your signature? Should only be 570 x 150
www.206info.co.uk/Foru...27931.html
bondyshambles
PostPosted: Sat May 18, 2013 11:07 am Up
Better ?
PostPosted: Sat May 18, 2013 11:29 am Up
bondyshambles wrote:
Better ?
Thumb Up The mods would just come on and delete it as it was. They may still do because of the width, but at least you've reduced the height by two thirds.
Can't really add much to Edwards advice about fitting. A good piece of scaffolding can help though.
PostPosted: Sat May 18, 2013 11:35 am Up
What mod's? Laughing
It's all quiet on the mod front again on here.
Dillon
PostPosted: Sat May 18, 2013 12:49 pm Up
Staff - Dillon
What He Said
