Latest: sparrowdclxvi
Overall: 17139
Online Now [109]:
Visitors: 108
Today: 39881
Total: 112613238
Forums › The Car › 206 Problems › i darent smoke in petrol fumed pug
eddie206
PostPosted: Thu May 23, 2013 9:19 am Up
Hi there...since i got the car its been stinkin of petrol and im sickened now but i cant find any leaks...the smell seems to be stronger just after filling up???
Does anyone have any experience with this problem?
Its just becoming a worry as the days get hotter...
eddie206
PostPosted: Thu May 23, 2013 9:20 am Up
Its a 2002,138gti petrol...thankyou.
Tolkienfan001
PostPosted: Thu May 23, 2013 9:27 am Up
Trade Rating: +13
Post moved from solved problems to 206 problems
2005 1.4 16v Sport
Check out my 206 here!
iainlovatt
PostPosted: Thu May 23, 2013 10:21 am Up
oh dear! could be something to do with the fuel pump! When you get a chance jack the car up get under it and see were the smell is coming from,
(My Garage)
PostPosted: Thu May 23, 2013 10:35 am Up
Lift the bottom of the rear seat on the drivers side and check the plastic seal on the fuel pump is tight.
Rob2859
PostPosted: Thu May 23, 2013 11:17 am Up
The plastic seal doesn't do anything anyway mine is only on loose as some plank broke it. Take it off and check the pump itself for leakage.
Wouldn't have thought the filler pipe was leaking but its worth a check as well. Check the injectors and rail for leakage as well, if its bad enough fumes could be working their way into the cabin.
derbitz
PostPosted: Thu May 23, 2013 1:18 pm Up
Does it get stronger when you have the blowers on ??
PostPosted: Thu May 23, 2013 2:43 pm Up
Well when you have the smell after refill,then I believe it's related with fuel pump,I had the same problem,and the fix was by buying a new seal (it's silicon made),you can buy a new one,and fit it,and your problem will be solved Smile
eddie206
PostPosted: Tue May 28, 2013 4:41 pm Up
Thanks guys...when i put the blowers on its worse for a second or two then better?
I know these pumps actualy and there a right b***h to loosen off from on top of the tank ...but i will see what i can do....as for the tank access hole cover im sure mine is quite loose so i will try to get some sticky back foam strip and some good tape and try and make a seal on the thing...if i cant see anything else at fault that is.
