Posted: Sat May 25, 2013 10:13 am |
Hi guys. Got my PP2000 yesterday and set it all up and have got a fault stored on my ECU. See picture below.
What does this mean? Do I need to replace my MAF? If so where best place to get one? I heard the cheap ones are a bit naff. Also, are second hand OEM ones worth a look at, or could I just be wasting my money there?
Any ideas would be great.
Thanks.
Brad
Posted: Sat May 25, 2013 11:05 am |
New OEM from eBay.
Might be something else though.
Posted: Sat May 25, 2013 11:08 am |
Press 'ENTER' and see if it gives you any more information.
Posted: Sat May 25, 2013 11:13 am |
Did press enter and is said something like 'controller 1 ready' ... wouldn't show any more info.
Thanks.
Brad
Posted: Sat May 25, 2013 2:22 pm |
give it a clean before u replace it
Posted: Sat May 25, 2013 5:58 pm |
I've done that before also. Got some electrical contact cleaner and cleaned it up.
Brad
Posted: Thu Jun 06, 2013 9:42 am |
ive got a maf sensor fault on my 206 hdi
P0100 flow sensor signal
P0101 air mass sensor circuit
did you get to the bottom of your fault ?
Posted: Fri Jun 07, 2013 4:33 am |
I haven't yet mate no. Plan to replace the maf though when get paid.
Brad
Posted: Sat Jun 08, 2013 11:10 am |
about to clean my maf and check the wiring see if it improves things on mine today will let you know how i get on maybe can compare notes from cleaning versis new part
Posted: Sat Jun 08, 2013 11:37 am |
Yea, be good mate. I'll let you know when I do get round to replacing my bit. Had to have my wheel bearing replaced today so that set me back a bit.
Brad
Posted: Sat Jun 08, 2013 12:13 pm |
Lowiee wrote: |
about to clean my maf and check the wiring see if it improves things on mine today will let you know how i get on maybe can compare notes from cleaning versis new part |
Cleaning the MAF with anything will more than likely knacker it, its quite sensitive. Looks like it needs replacing by the sounds of it. The car will be running on preest values until the fault is repaired and cleared.
Posted: Sun Jun 09, 2013 6:39 am |
Lowiee wrote: |
did you get to the bottom of your fault ? |
Lowiee, got some more info on my fault and its P0100 same as you so am going to replace as soon as I can.
Brad
Posted: Sun Jun 09, 2013 8:11 am |
i cleaned my maf yesterday the idle is now settled around 950 rpm it was full of carbon crap but the connector was spotless so gotta wait for the code reader ive ordered to see if the fault codes have come back btw were did you get your p planet from ?
Posted: Sun Jun 09, 2013 9:16 am |
What software is that you are using?
Posted: Sun Jun 09, 2013 10:59 am |
Lowiee wrote: |
i cleaned my maf yesterday the idle is now settled around 950 rpm it was full of carbon crap but the connector was spotless so gotta wait for the code reader ive ordered to see if the fault codes have come back btw were did you get your p planet from ? |
Got it from DHgate.com ... was about £55
Steve137 wrote: |
What software is that you are using? |
Its Peugeot Planet, pretty good tool for diagnostics on the pugs
