Latest: heikkisj
Overall: 17126
Online Now [38]:
Visitors: 37
Today: 15981
Total: 100213589
Forums › The Car › 206 Problems › Running problems 2.0HDI
Brendanmidds
PostPosted: Sun May 26, 2013 12:34 pm Up
Hi my 2.0 hdi is running for approximately 10-15 seconds before it stalls I go to restart and the lift pump sounds asif it is locking up. I plugged my Snap-on diag computer in the car and come up with the high pressure regular so I have changed that and made no difference to the running I have also changed the lift pump to rule that out any ideas guys? Need my car for work Tuesday Sad
PostPosted: Sun May 26, 2013 1:12 pm Up
have you tried to change the diesel filter?
Brendanmidds
PostPosted: Sun May 26, 2013 3:00 pm Up
Was new 4months ago and I have checked it and is still clean
PostPosted: Sun May 26, 2013 3:19 pm Up
Well does it cut off on high engine revs,and go to limp mode?if so,then you need to replace the fuel pressure regulation solenoid which control the pressure of the pump,which is controled by the ECU
Brendanmidds
PostPosted: Sun May 26, 2013 3:58 pm Up
It is in limp mode and I have replaced the fuel pressure regulator
DREWDEN
PostPosted: Sun May 26, 2013 7:17 pm Up
Is your engine management light on.
206 2ltr Hdi glx 53 plate
Brendanmidds
PostPosted: Mon May 27, 2013 1:20 am Up
Yes and it comes up with high pressure fuel reg so I changed that Sad n made no difference
DREWDEN
PostPosted: Mon May 27, 2013 5:52 am Up
Does your MFD flash up anti- pollution fault by any chance.
Brendanmidds
PostPosted: Wed Jun 05, 2013 4:18 am Up
i dont have a MFD XD haha and thanks for all your help guys i have got her back on the road and turns out i changed the high pressure fuel pressure sensor so i changed the regulator in the end of the pump and she is running better then before and using less fuel then before so my guess is that is was a on going problem that i have resolved Very Happy so happy ahaha
