Latest: DanDan17
Overall: 17128
Online Now [62]:
Visitors: 61
Today: 16154
Total: 100536087
Forums › The Car › 206 Problems › enlighten me
enlighten me
mickha
PostPosted: Sun May 26, 2013 4:20 pm Up
Just finished doin all the brakes !!!! painted calipers,caliper holders, back plates and new brembo discs (yes just the bits pads dont touch). All sliders cleaned new copper grease now just the easy bit tomorrow puttin it back togther. Question on the rear brake piston why do 2 of the knogins have groves and 2 plain ????? do they need to be postioned in a certain way when puttin the pads in ???? or does it not matter as long as the pin on the pad is lined up with the groove
Cheers
iainlovatt
PostPosted: Mon May 27, 2013 2:41 am Up
Oh dear,, you need a rear brake compression tool!
(My Garage)
mickha
PostPosted: Mon May 27, 2013 3:23 am Up
Ian
Can you explain ????
iainlovatt
PostPosted: Mon May 27, 2013 3:40 am Up
Yes,
You need to use a tool to wind the piston back into place. Then the pads will sit in the place, put this number into eBay.
151033228969
I'm on my phone which is why I can't do the link properly,,
Also why have you posted the same problem 3 times?
(My Garage)
mickha
PostPosted: Mon May 27, 2013 3:49 am Up
Ian
I can wind the piston back in no problem i'm just confused as to why the piston has these grooves on 2 of the lugs ie does it have to be positioned in a certain way or is it just a case of there to locate a compression tool if used. Realised id posted in How to@s rather than Problems hence duplicate.
PS. On a personal note deeply regret not buying your interior now struggling to find something thats anywhere near as good.
iainlovatt
PostPosted: Mon May 27, 2013 4:07 am Up
They are there for the compression tool (i think)
Interior sold 3 days later for the full asking price, it was a steal. Very Happy
(My Garage)
PostPosted: Mon May 27, 2013 5:41 am Up
You can easily wind them back with a screwdriver, you need to line up one of the marks on the back of the pad with the brake piston.
PostPosted: Mon May 27, 2013 6:52 am Up
Yep I've got a decent piston rewind kit but there's no space on the Peugeot rear calipers so a screwdriver is very easy to use on them.
PostPosted: Mon May 27, 2013 2:28 pm Up
www.youtube.com/watch?v=lcqXz42jM30
DREWDEN
PostPosted: Mon May 27, 2013 3:19 pm Up
Very funny had a good laugh.
Got the gist of it.
206 2ltr Hdi glx 53 plate
