Online Now [1548]:
Visitors: 1547
Today: 277783
Total: 150863747
Forums › The Car › 206 Problems › Car keeps stalling itself when cold & low revs :(
Raquelle
PostPosted: Fri May 24, 2013 2:59 am Up
Hi,
Basically my car 90% of the time, when I'm reversing out of my parking space in the morning will stall, even though its being driven properly, if I give it some revs & slip the clutch a lot it's fine. It also tends to do it being driven off after sitting for a day or so.
It's fine if its been used within a few hours but otherwise a pain in the ass!
Can someone tell me what it could possibly be, the idle control valves been changed as prior to a fuel injector failing, had issues with the car getting bored in traffic and revving itself like mad.
Thanks Smile
PostPosted: Fri May 24, 2013 5:54 am Up
Model, year, engine, temp sensor?
PostPosted: Fri May 24, 2013 7:26 am Up
Battery showing firsr signs of ageing.
Mr-Tigger
PostPosted: Fri May 24, 2013 12:59 pm Up
idle air control,blocked cat,poor injector performance,rocket ignitor pack wearing (well,without knowing what car you have it could have one)
PostPosted: Sat May 25, 2013 8:22 am Up
Ah yes, that too.
Raquelle
PostPosted: Mon May 27, 2013 9:56 am Up
My bad, SORRY used to be in my signature tis a 2001 1.4 petrol and can't be the battery, I bought a new one a few months ago, which is under warranty if it turns out that - which I doubt.
Guessing its another injector going then, occasionally have a fault come up, unfortunately till it fails its difficult to tell which one it is.
DREWDEN
PostPosted: Mon May 27, 2013 10:03 am Up
[quote="Raquelle"]occasionally have a fault come up,
What fault is that.
206 2ltr Hdi glx 53 plate
