Latest: DanDan17
Overall: 17128
Online Now [55]:
Visitors: 54
Today: 16157
Total: 100414341
Forums › The Car › 206 Talk › External Temp Sensor
Jordyn
PostPosted: Thu Jun 13, 2013 4:07 pm Up
Hey i just installed the 3 Line display and it has the temperature on it but i don't have the sensor i have manual mirrors and have a 2 pin connector in both doors that I'm guessing is for the temp but i can't find any sensors with the correct plug any help with this issue would be great thanks a lot Very Happy
206-GTi
PostPosted: Thu Jun 13, 2013 4:11 pm Up
Could you not swap out the manual mirrors for electric mirrors? Just need to make sure the loom is the same type I think, and of course get the Electric switch Smile
Fantastic upgrade also!
GTi - Black - 2002
Jordyn
PostPosted: Thu Jun 13, 2013 4:21 pm Up
I have looked in to that but don't think my loom is correct as only have the 2 pin connector behind the tweeter covers
PostPosted: Thu Jun 13, 2013 4:33 pm Up
most temp. sensor come along with the electric mirrors,but you can google it,as you might find new or used one for sale
206-GTi
PostPosted: Thu Jun 13, 2013 4:34 pm Up
I'm sure others will be able to assist with this and give you a better idea, I've never done it but started to look when I had the XS, I ended up getting the GTi shortly after so didnt need to go further.
GTi - Black - 2002
Jordyn
PostPosted: Thu Jun 13, 2013 4:38 pm Up
Thanks i have been looking for the temp sensor and seen a couple with just the wires no connector so would it just be a case of removing the connector and then soldering the wires ?
PostPosted: Fri Jun 14, 2013 3:59 pm Up
Yes.
