Latest: sparrowdclxvi
Overall: 17139
Online Now [104]:
Visitors: 103
Today: 18352
Total: 112673284
Forums › The Car › 206 Problems › Pre plexed not starting
Chris201009
PostPosted: Wed May 29, 2013 6:15 am Up
Hi guys
My 1.1 206 pre plexed won't start, I think it may be the battery, however I'm not sure. If anyone could give any advice or offer suggestions that would be greatly appreciated.
Cheers
iainlovatt
PostPosted: Wed May 29, 2013 6:38 am Up
what happens exactly?
(My Garage)
Chris201009
PostPosted: Wed May 29, 2013 7:06 am Up
Nothing really, turn the key and get the usual lights on the dash n not much more than that other than a ticking noise
20Drift
PostPosted: Wed May 29, 2013 7:28 am Up
Do you hear the starter motor turn at all?
iainlovatt
PostPosted: Wed May 29, 2013 7:33 am Up
go and get some jump leads! Might be a battery!
(My Garage)
DREWDEN
PostPosted: Wed May 29, 2013 8:09 am Up
Try this, give the starter motor a few taps with an hammer, (solanoid probably sticking)
206 2ltr Hdi glx 53 plate
PostPosted: Wed May 29, 2013 12:47 pm Up
Sounds like the battery, doesn't always have to be something major. Start with the easiest options.
Jack123
PostPosted: Wed May 29, 2013 3:40 pm Up
Had the same problem, could hear ticking, was a flat battery as the car had sat for so long, fired up straight away once I charged the battery
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
PostPosted: Thu May 30, 2013 2:30 am Up
+1
Might be sticking.
-1
Don't jump start a 206 as there is a very real risk of damaging control units.
It can take months for problems to appear and diagnosing them is often a pain.
A lot of people will say I've done it loads of times and no problem but there's too many factors that affect this issue to be sure.
It is much better to isolate battery (dis-connect) and use a charging unit for the job, unless in an emergency situation.
'My 2 Yen.
DREWDEN
PostPosted: Thu May 30, 2013 10:59 am Up
DREWDEN wrote:
Try this, give the starter motor a few taps with an hammer, (solanoid MIGHT be sticking)
I am saying this, as an assumption that the car has been starting ok in the last 24 hours or so.
If it was the battery then normaly you would still have a bit of life still there, turning over, but not quite starting, then a few more attempts, until nothing at all.
PostPosted: Thu May 30, 2013 11:37 am Up
Put the lights on. Turn the engine over. If the lights go off then there's no power in the battery.
Chris201009
PostPosted: Thu May 30, 2013 2:58 pm Up
Thanks for all the advice guys,
I've had the battery on charge since yesterday put it back on n it fired up first time.
Problem solved Very Happy
