Online Now [1286]:
Visitors: 1286
Today: 258440
Total: 151381611
Forums › The Car › 206 Problems › Whistling noise.
Whistling noise.
tommy89
PostPosted: Wed Jun 05, 2013 4:39 pm Up
Finally got the 206 going as a daily driver after some minor work at the garage.
When driving tonight I noticed a small problem - When travelling along at a steady 60mph on a dual carriage way it was making a small whistle noise - This whistle noise increased in volume as I floored the accelerator - Didnt seem linked to speed and only happened when driving quickly.
Does this sound Like an air intake issue? My old clio used to whistle as it had a hole in the air pipe - Haven't had a chance to look yet - does the 206 have an air intake pipe that is liable to cracking?
Thanks in advance for any help!
OH! sorry - its a 1999 206 1.1 L on 95000 miles Smile
DREWDEN
PostPosted: Wed Jun 05, 2013 6:55 pm Up
Not something simple like a door window (not fully up)
206 2ltr Hdi glx 53 plate
Lowiee
PostPosted: Thu Jun 06, 2013 6:27 am Up
have you checked the driver door seal ?
tommy89
PostPosted: Thu Jun 06, 2013 2:51 pm Up
I havent no - Thank you for the tip you two Very Happy
I will go and investigate!
bexsta
PostPosted: Mon Jun 10, 2013 2:51 am Up
my quicksilver does this too !! uummm
tommy89
PostPosted: Mon Jun 10, 2013 12:49 pm Up
I have checked the door seals (both are fine), windows are all shutting fine, bonnet isn't wonkey, no snapped bodywork......
I checked the air intake (took the air box off and pipe) couldn't see any cracks or holes... unless its leaking from around the plastic joints? do the air pipes usually have some sealant around the joins?
Its really annoying now! only seems to do it when hot, and increases with acceleration press not necessarily speed. No point sending it to the garage as it doesn't always do it.
I kinda want this fixed - taking it on a booze cruise in 8 weeks. any ideas are greatly appreciated!
