Posted: Tue Jun 04, 2013 10:50 am |
As stated whats the best oil to use in my 1.6 16v xsi as i plan on dropping the oil out and changing the filters soon. Sometimes at present the car is making a slight ticking (tappety) noise on cold morning start ups then fine once warm so im hoping a decent oil replacement will solve this.
| 1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems." | |
Posted: Tue Jun 04, 2013 11:01 am |
Trade Rating: +13
Do you have a owners handbook? It says in there.
Posted: Tue Jun 04, 2013 11:04 am |
total quartz!
Posted: Tue Jun 04, 2013 11:21 am |
better than the likes of Castrol?
Posted: Tue Jun 04, 2013 11:56 am |
Well it's what Peugeot recommend.
Posted: Tue Jun 04, 2013 12:36 pm |
You need to use Total Quartz 5W/30 Synthetic
You will need 3,0 Liters with filter changed.
Posted: Tue Jun 04, 2013 4:20 pm |
Castral edge is very good I use that in mine. Seemed to run cooler on scan gauge as well.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Thu Jun 06, 2013 1:28 pm |
i have miilers nano oil in my 180 great stuff
| 206 gti 180 project in shutting tits up | |
Posted: Fri Jun 07, 2013 4:37 am |
I've got the 2.0 Hdi and use Mobil 1 turbo diesel ... Seems pretty good to me.
Brad
