Online Now [589]:
Visitors: 589
Today: 184553
Total: 151959533
Forums › The Car › 206 Problems › Code p0204
Code p0204
Boydie
PostPosted: Thu Jul 11, 2013 8:21 am Up
Hi..just noticed that my car kept losing a cylinder after the car was ticking over but while driving it would kick back into four again. Pluged computer in and the code p0204 came up (injector circuit malfunction cylinder 4) just wondering is it a new coilpack i need to get or new injectors or what?
Thanks in advance
Gti 180
PostPosted: Thu Jul 11, 2013 8:27 am Up
Injector #4 has a very bad reputation of getting dripped-on with water from the far-side windscreen washer-jet fittment.
This leads to corrosion of it's connector and there's been a Peugeot Info-flash about this problem.
OR it might have nothing to do with it.
PostPosted: Thu Jul 11, 2013 9:01 am Up
Shouldn't be relevant in this case as it's a GTi and the injector's are on the front of the engine, out of harms way of the washer jets.
PostPosted: Thu Jul 11, 2013 10:42 am Up
Ah, yes.
I forget others exist appart from the 1.4i sometimes. Laughing
My appologies - not relevant to your model.
Boydie
PostPosted: Fri Jul 12, 2013 9:57 am Up
Anyone have any ideas?
Gti 180
Boydie
PostPosted: Sat Jul 13, 2013 7:05 am Up
Anyone know?
Gti 180
Deckchair5
PostPosted: Sat Jul 13, 2013 11:09 am Up
You could put injector cleaner in the tank and see if that does the job as it's pretty effective
With an engineers stethoscope or even a screwdriver on top of the injector you could listen to the injectors firing and compare
Swop bad injector over with a good injector position and see if the fault follows it. If it does = problem injector, if not then it points to a circuit problem.
With a multimeter you could check the injector signal and ground and resistance compare the injectors. High resistance from ECU to injector will set the P0204, as will a short circuit of course so you could check the wiring
If you have an injector tester then you can check whether the injector is operating at low rpm
If you have a scope then you can look at the injector signal trace
