Posted: Sat Jun 08, 2013 1:36 pm |
The 206 has the airbag light on,normally the wires under the seat, but this one hasnt got airbags in seat, any way i just read it with pp2000 and it said this:
Permanent fault level of driver module trigger 1 open circuit
any ideas?
Posted: Sat Jun 08, 2013 2:47 pm |
well you need a new Com2000 unit mate,because all the faults with Module trigger is caused by
(1) Poor connection at the two pin blue or brown connector on the back of the Comms 2000.
(2) Poor connection at the two pin blue or green connector on the back of the drivers (steering wheel) module.
(3) Intermittent break in the rotary connection built into the Comms 2000.
I think Module 2 are the blue connectors whilst module 1 are the green and brown connectors.
so if you have any problem with those,then you need to replace the COM2000 unit,as these can't be fixed
Posted: Sat Jun 08, 2013 3:47 pm |
Trade Rating: +13
You can get one from ECP. And there is a guide on here to help you replace it. Remember to disconnect the battery properly and reconnect as per the BSI reboot procedure.
