Posted: Fri Jun 07, 2013 4:02 pm |
206 1999 1.1 l 95k
The car is making a clonky noise along side its whistling noise (mentioned in a previous thread) - this is a noise that happens when I pull off or floor it in any gear...
This does sound like the drive shafts - but they wer echanged two years ago (fully documented from a trusted source)
the previous owner has no recollection of this noise (family) but didnt understand what I was on about.
Is this a normal noise for the 1.1's? I have never had one before - pretty crappy if it is normal as it sounds like the car has no oil (It does) .
Posted: Fri Jun 07, 2013 8:56 pm |
1) Have the valve tappet gaps been checked ever?
2) Left-hand gearbox-to-chassis mount is also so important I don't know where to begin.
Posted: Sat Jun 08, 2013 7:42 am |
Looking at your mileage, worth asking (family) if the clutch has ever been changed. Or looking at any maintenance reciepts, records.
Thrust bearings can make a whistleing noise.
When driving say in 3rd or 4th gear dip your clutch and see if the whistleing noise comes and goes as you do it.
| 206 2ltr Hdi glx 53 plate | |
