Online Now [1138]:
Visitors: 1137
Today: 463139
Total: 153857604
Forums › The Car › 206 Talk › Trip Computer / Outside Temp Sensor
Forum Index › 206 Talk
Jordyn
PostPosted: Sun Jun 09, 2013 11:26 am Up
Hey i have a 54 Plate 1.1 Zest and it currently has the single line clock display and wanted to know if it would be possible to add the multi line Display with the trip computer i have checked my wiper stalk to see if it had the button under the cap and believe it has would it just be a case of fitting the new display and activating it on the bsi ? and finding a button for the end of the wiper stalk. Also i would like to add the outside temp sensor i have a two pin connector behind the tweeter cover and wanted to know where i could get the sensor for it from.
Thanks alot
PostPosted: Sun Jun 09, 2013 11:50 am Up
Thanks alot
Same here.
PostPosted: Sun Jun 09, 2013 12:25 pm Up
OP, yes you can do it, pretty much as you say.
V977 is yours pre or multiplex? If it's pre cant have the trip computer, but cant see any reason why you cant go to the ppt 40 (could be 30 cant remember off the top of my head) and run a temp sensor on that.
PostPosted: Sun Jun 09, 2013 1:17 pm Up
Lee, this is for the other one which is mux and has the display already.
Not interested in trip computer but temp would be nice and has the connector waiting..
Cheers for reply.
Jordyn
PostPosted: Sun Jun 09, 2013 1:40 pm Up
do you know where i can buy the temp sensor to fit that connection ?
PostPosted: Sun Jun 09, 2013 2:36 pm Up
the temp sensor can be bought from ebay,but usually it's stick with the side mirror wires Smile
Jordyn
PostPosted: Sun Jun 09, 2013 2:46 pm Up
Thanks i can only see ones with no connector ends would i just need to wire it up to the wires there and bypass the connector
pug206lx
PostPosted: Sun Jun 09, 2013 5:42 pm Up
Im pretty sure that a mux car should already have a temp sensor, press the right hand button on the display and it should show temperature instead of the time.
PostPosted: Sun Jun 09, 2013 5:57 pm Up
Ours doesn't, only the connector.
