Latest: williamekstrom
Overall: 17124
Online Now [75]:
Visitors: 74
Today: 10489
Total: 99342518
Forums › The Car › 206 Problems › 206 lexus lights
206 lexus lights
brommas
PostPosted: Fri Aug 22, 2014 9:13 am Up
Hi all, i just picked up a dirt cheap pair of 2nd hand Lexus lights for my 2003 1.1 8v . the only problem is that 1 of the units is missing its connector and loom.
Does anyone have any ideas where i can either make 1 up from, or buy the correct part, Ebay and Google really have turned up a blank.
Thanks in advance.
2003 - 1 owner and me from new 91k new cambelt kit, clutch, droplinks, 2 new driveshafts, 1 damaged n/s bottom ball joint and arm replaced. just bought a refurb com 2000 for it also.
PostPosted: Fri Aug 22, 2014 9:28 am Up
You may find some spares in the 90s when Lexus lights were in fashion.
Best way to sort it is cut the loom off the other one and then using a hefty hammer give each lens 3 good taps with the heavy end.
You may find that a sledge hammer gets the best results.
They were dirt cheap for a good reason, and not just because one wasn't complete.
iainlovatt
PostPosted: Fri Aug 22, 2014 10:00 am Up
the only chance you have got is to take the loom from another set of lights. But then i wouldn't recommend it as you will be righting them off.
Best bet would be to buy another lexus light on its own off the likes of ebay.
However it must be said, they really dont justify having them on a 206. A lot of people including myself chose LED rear lights as the way forward, but each to there own!!
(My Garage)
brommas
PostPosted: Mon Aug 25, 2014 8:27 am Up
Most people think i am stuck in the 80's, so at least i am a decade further forward by your estimation :). thx for the answer
