Latest: heikkisj
Overall: 17126
Online Now [66]:
Visitors: 65
Today: 19841
Total: 100392530
Forums › The Car › 206 Problems › Quicksilver Problem
Quicksilver Problem
IceWhyte
PostPosted: Tue Jun 11, 2013 3:22 pm Up
Hey,
I have a 1.4 16v 2005 Quicksilver and find it hard searching for parts as the model "Quicksilver" is never used.
Apparently I need a new coil pack and have searched eBay and looked on that service box site which says that the 206 1.4 16v requires the 5970 85 coil pack so how can I be sure that it is right for my car?
I sent the mechanic a picture of it and he says it looks different.
Tolkienfan001
PostPosted: Tue Jun 11, 2013 3:30 pm Up
Trade Rating: +13
I think you have to be careful with spark plugs and coil packs. Some of the guys on here will steer you in the right direction.
Have you tried carparts4less, ECP etc? You enter your reg then search for the part. I personally would not buy a coil pack from eBay.
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Wed Jun 12, 2013 3:31 am Up
Did you enter your VIN on servicebox? If you did, then that's the right part number.
IIRC, you have to be careful which make of coilpack you fit. Can't remember which one has issues, but it will be on the site somewhere.
PostPosted: Wed Jun 12, 2013 4:53 am Up
The socket colour (on the coilpack) has to be the same for starters.
The connector colour of the loom which plugs-in might well not be the same as the coilpack socket colour - this is normal.
You have to get absolutely the right part as there's quite a few versions and it's not immediately obvious that you've put-in the wrong one.
Under these circumstances I would go for a genuine coilpack in it's sealed plastic bag, with the part code staring at you.
Nellie
PostPosted: Thu Dec 26, 2013 1:42 pm Up
Hi In my opinion there are only two types of coil pack's and the connecting plug's are different colours and you must get the same colour as the old one.
Simples!!!
Neil
Neil C
PostPosted: Thu Dec 26, 2013 2:14 pm Up
I 'think' i have a brand new valeo one for sale if you intrested? Brand new and genuine, just the connector is a little broken but this does not harm it at all
PostPosted: Thu Dec 26, 2013 7:40 pm Up
Simples!!!
Neil
It isn't as I found out quite nicely..
See post above.
