Posted: Wed Jun 12, 2013 6:20 am |
Hi people,
Having a problem adjusting the drivers seat on a 180. It seems to have sunk to the lowest position and the height adjuster isn't working.
Any ideas?
Posted: Wed Jun 12, 2013 8:31 am |
a new seat would be a good idea,but you can also search for the new jack which lift it up
Posted: Wed Jun 12, 2013 9:08 am |
Hopefully just the height adjuster, will take another look tonight.
It just moves around like it's not attached to anything. Everything else works fine.
Posted: Wed Jun 12, 2013 2:00 pm |
dangerpowers wrote: |
It just moves around like it's not attached to anything. Everything else works fine. |
Take the seat out and have a look at the mechanism... 9 out of 10 time it's usually just worked itself loose over time and just needs reassembling.
Posted: Thu Jun 13, 2013 5:54 am |
Uz wrote: |
Take the seat out and have a look at the mechanism... 9 out of 10 time it's usually just worked itself loose over time and just needs reassembling. |
Good idea thanks, will try that.
