Latest: jtq4u
Overall: 17141
Online Now [92]:
Visitors: 91
Today: 28138
Total: 113997201
Forums › The Car › 206 Problems › Violent shaking under hard acceleration between 35 - 50mph
AndrewR2211
PostPosted: Fri Jun 28, 2013 4:55 am Up
Hi, me and a friend recently installed coilovers, now everything went fine, the only thing that shouldnt have happend was that we pulled a driveshaft out, but that slid back in, everything is tight, and where it should be, however now under hard acceleration between 35 - 50mph the gearstick bounces really badly and the car shakes violently, i have checked all the obvious things like wheel bearing and wheel weights, but we cant work it out :/
lukepug19
PostPosted: Fri Jun 28, 2013 5:28 am Up
I have just had a similar problem and mine was the driveshaft it self
234re
AndrewR2211
PostPosted: Fri Jun 28, 2013 6:14 am Up
So you had no feeling or shaking in the wheel, just the gearstick and car? also it stops after 50 mph?
PostPosted: Fri Jun 28, 2013 6:22 am Up
Did the drive shaft split at the inner CV joint? If you put it back in make sure the spring is central it's very easy for it to become miss aligned, and will cause exactly what you are experiencing.
AndrewR2211
PostPosted: Fri Jun 28, 2013 6:52 am Up
All the CV joints are still in tact..i think, and i cant put my finger on what you mean? The spring? i never noticed any spring, we basically slotted it back in :/
PostPosted: Fri Jun 28, 2013 12:16 pm Up
The inner CV boot has a spring to ensure that the equal length shafts stay central to each other - if the boot never slid off chances off it's alright as it won't have come far enough for it to dislodge. But it's worth checking anyway. It happened to me so I know it's a likely culprit, especially if you split the wishbone as just the weight of the shaft is enough to pull it out.
lukepug19
PostPosted: Fri Jun 28, 2013 12:17 pm Up
yes exactly the same problem I didn't notice mine was split until I took the wheel off and had a proper look the spring had nearly fallen out
234re
PostPosted: Fri Jun 28, 2013 12:23 pm Up
Driveshaft(s) up the spout.
AndrewR2211
PostPosted: Tue Jul 02, 2013 9:22 am Up
Got it sorted, turns ojt it was the left hand side driveshaft, there are three pins, interlocking woth three pins which lets the driveshaft bend, one of the pins had fell out therefore alowing the.driveshaft to jump up and down at a certian point.
My 206 Sport
