Posted: Sun Jun 16, 2013 6:06 am |
I've noticed recently when im in slow traffic my water temp gauge is going up into the red (its happened twice) and he 'stop' light is flashing on the dash. Ive noticed that the temp reading quickly drops when the car picks up speed. Any ideas?
| '02 206 Quiksilver. SP Kit. Gloss black 205 Speedlines. ICC Tuning WRC spoiler (civic style). Sparco Rally Flaps. Laguna splitter. Upper and lower front Struts. V-Maxx front coilovers and Apex rear shocks. GTI180 front Arb. GTI180 front brake set up. 4-2-1 Mani, 200cell sport cat, stainless pipes and sportex 3" rolled box. Gloss black morettes with yellow lenses. Yellow tinted fogs with yellow bulbs. | |
Posted: Sun Jun 16, 2013 10:21 am |
Sounds like its the Radiator fan not working
| GTi 180 - Scorpion Exhaust | |
Posted: Sun Jun 16, 2013 12:50 pm |
probably a burnt radiator fan resistor! Have a look under the car.
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Wed Jun 19, 2013 7:29 am |
| Lewis wrote: |
| probably a burnt radiator fan resistor! Have a look under the car. |
what do I look out for?
Posted: Wed Jun 19, 2013 8:51 am |
More likely to be corroded relay terminals or the wiring to the relay is corroded through. The 2 x relays are behind the panel on the radiator housing.
