Latest: DanDan17
Overall: 17128
Online Now [164]:
Visitors: 163
Today: 12852
Total: 100613271
Forums › The Car › 206 Problems › Electric valve?
Electric valve?
elcamino
PostPosted: Sun Jun 16, 2013 3:27 pm Up
There is an electric valve just behind the water expansion bottle.when u trace suction line on air intake manifold you can find it there(a plug with 2 wires connected to it)does anyone know whats this and whats the function? thanks
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Sun Jun 16, 2013 3:42 pm Up
you mean the light brown one?
elcamino
PostPosted: Sun Jun 16, 2013 3:47 pm Up
yes i think
PostPosted: Sun Jun 16, 2013 4:19 pm Up
That is called "canister solenoid valve",it's job to regulate the fuel evaporation passage from the fuel tank to the engine and back to make sure there is no wastage in the burn process.
elcamino
PostPosted: Sun Jun 16, 2013 4:30 pm Up
Thanks.you mean the upstream of this valve connected to fuel tank?what will happen if it doesnt work?and why is connected to air intake manifold?i mean sucks fuel to air manifold?
PostPosted: Sun Jun 16, 2013 4:37 pm Up
it sucks the not burned fuel from the engine,and sends it back to the fuel tank as vapor,so it get back as fuel,it does not work all the time,only when the fuel burn is rich,u will hear it clicking,if it's not connected or not working,the car will smell as you have petrol leakage.
