Latest: Mr-Koekwaus
Overall: 17125
Online Now [43]:
Visitors: 42
Today: 3709
Total: 99429267
Forums › The Car › 206 Problems › Diagnostics generic error code P0221 help?
very_452001
PostPosted: Tue Jun 18, 2013 10:01 am Up
Engine management light came on the dashboard. The light wasnt flashing, it was constant on.
Anyone had/experienced this error code before?
generic error code P0221:
Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
which one is it?
Its a 2006 1.4 peugeot 206
very_452001
PostPosted: Tue Jun 18, 2013 10:10 am Up
Someone else has had it www.206info.co.uk/Foru...c/t=54863/
Is this the same fault as you had in November?
www.206info.co.uk/Foru...c/t=50960/
very_452001
PostPosted: Tue Jun 18, 2013 11:14 am Up
the 1st one isnt.
Where are the 2 TPS and the APP sensors?
very_452001
PostPosted: Tue Jun 18, 2013 2:50 pm Up
the 1st one isnt.
He gave you the link because you have the same problem as that guy,but ofcourse not the brake light switch,that guy had fixed his problem as you read,and you can do the same,if you don't know much about that,take a look at this thread,might be helpful and give you an idea on what to do and what to take off
Cleaning Throttle Body
very_452001
PostPosted: Tue Jun 18, 2013 6:42 pm Up
the 1st one isnt.
Before I do that I like to know where are the Where are the 2 TPS and the APP sensors? Are the 2 TPS sensors in the throttle body?
very_452001
PostPosted: Tue Jun 18, 2013 7:29 pm Up
Sounds like either your pedal (Accelerator Pedal Position) or the motorised throttle body (Throttle Position Sensor) are throwing up the code.
very_452001
PostPosted: Wed Jun 19, 2013 5:00 am Up
Is there pics showing where those sensors are?
Is this a serious problem? Will the problem get worser if i ignore it or will it effect driving like mpg?
very_452001
PostPosted: Wed Jun 19, 2013 5:32 am Up
You should not ignore EML coming on.
Assuming your setup is as I understand it (drive by wire) the pedal is electric (APP) and the throttle butterfly is motorised and contains the TPS in it.
A pic of your engine bay would help.
very_452001
PostPosted: Fri Apr 25, 2014 11:09 am Up
Ok there's 5 possible fixes:
- Throttle Position Sensor (TPS) harness is open or shorted
- Throttle Position Sensor (TPS) circuit poor electrical connection
- Faulty Throttle Position Sensor (TPS)
- Fault Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP)
Which one is the common likely fix?
very_452001
RichardEke
PostPosted: Sat Apr 26, 2014 3:24 am Up
Morning,
I would plug in a code scanner that does live data. Then look at the TPS(%) when the key is in the ignition but the car not running.
That would probably give you the best idea what's going on.
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
very_452001
PostPosted: Sun Apr 27, 2014 12:37 pm Up
RichardEke wrote:
Morning,
Regards, Richard.
Thanks for the advice. I keep you guys updated with the results.
very_452001
very_452001
PostPosted: Sat May 03, 2014 5:47 am Up
update:
with my Vgate VS550 diagnostic code scanner I plugged it in to my 206 and obtained the following result located in live data menu under datastream menu:
TP is 9.8%
Any advice?
very_452001
very_452001
PostPosted: Mon May 05, 2014 12:38 pm Up
bump anyone?
very_452001
mtempsch
PostPosted: Mon May 05, 2014 1:38 pm Up
very_452001 wrote:
update:
TP is 9.8%
Any advice?
Was the 9.8% constant - no change when you push down the accelerator pedal?
Silvermetallic 2004 206 RC
very_452001
PostPosted: Tue May 06, 2014 5:46 am Up
mtempsch wrote:
very_452001 wrote:
update:
TP is 9.8%
Any advice?
Ok I do the test including the new parameter you just mentioned. I was advised by member RichardEke above to check TPS while engine not running.
With the new parameter you mentioned do you want me to the run the test with the engine on or off?
Any other parameters apart pushing the gas pedal you want me to include in the test?
very_452001
