Latest: Mr-Koekwaus
Overall: 17125
Online Now [195]:
Visitors: 194
Today: 35484
Total: 99420648
Forums › The Car › 206 Problems › Urgent!!! Got small drops of water in oil
Joethepet
PostPosted: Sat May 03, 2014 7:48 am Up
I have small drops of water in my oli. Ive changed he rocker cover gasket and thats when i noticed it. Im changing the oil, filter and sump gasket. Will that do the trick?
PostPosted: Sat May 03, 2014 8:16 am Up
Might just be some condensation.
No point changing things until you know the source of the problem.
PostPosted: Sat May 03, 2014 10:18 am Up
Could be the result of a few short runs, maybe it just needs a nice long run to get the oil up to temperature. Or it could be the head gasket.
paulspug
PostPosted: Mon May 05, 2014 2:13 am Up
when I bought my gti a while back , it had a lot of milky stuff in the oil cap , which helped me knock down the price. I took a chance as I knew it had been standing for a few months through the winter.
got home changed the oil/filter and that was the exact problem it had, as from then on all was ok.
If your car is using a lot of water or oil and it gets hot a lot, then maybe it might be the head gasket.
try what macca and E5GDM says first before you make any drastic decisions
Joethepet
PostPosted: Sat May 10, 2014 5:35 am Up
Thanx for your responses i change the oil/filter/sump and rocker gasket and it seen to have done the trick. The work needed doing anyway so just got on with it.
Cheers lads
