Latest: eltel666
Overall: 17146
Online Now [139]:
Visitors: 138
Today: 23748
Total: 116160741
Forums › The Car › 206 Problems › com2000 : ecu not replied !!!
emhtuning
PostPosted: Thu Jun 20, 2013 1:10 am Up
Hello everyone , another funny thing happened last night while I was installing stalk adapter for JVC HU that i installed few weeks earlier .
the adapter is plug and play , tested it and everything works well , then i decided to cut the P&P harness since it took huge space at the back of the HU , connected the wires directly one by one as per the diagram on the actual harness of the adapter . the mistake I did is I kept the ignition on while doing the wiring job .
all of the sudden , I got Engine Immobilizer error , car doesn't start , remote key doesn't lock or unlock the car .
after many diagnosis and reading online , I hooked up the PP2000 , and the switch module under the steering is not replying , I tried to check if there is a fuse related to it , but I couldn't find anything .
Could it the Switch module is gone, or its just a fuse or something to make it working again ,
I called the dealer today and they said it's 760$ and needs 3 weeks for order to arrive,
if anyone have an advise it will be highly appreciated .
the car is 206RC ( GTI 180 ) 2005 model .
Crying or Very sad
PostPosted: Thu Jun 20, 2013 3:36 am Up
Clone interface?
emhtuning
PostPosted: Thu Jun 20, 2013 3:44 am Up
V9977 wrote:
Clone interface?
Yes . Does it make a difference , I do many things with it usually .
All other modules are working just fine
